Sonoff Pow voltage spikes when not in use
I have recently placed a Sonoff Pow running TASMOTA on my washing machine, and it has been working great with voltage detection to turn it off when it has finished a washing cycle.
The issue is the Sonoff seems to have small voltage spikes randomly throughout the day when it is switched off. Perhaps this is from WiFi, but I wouldn’t have thought it would go as high as 9-10 watts to ping WiFi. It seems odd. It’s almost like it is being turned on momentarily.
You can see the small spikes in the below picture. Is this an issue, is there a solution that someone knows off? Thanks in advance.
Capture
During the day the Sonoff is switched ON or OFF?
Switch on at the wall, the Sonoff itself is switched off.
Which version of Tasmota do you use?
Thee observations:
  1. As far as I can understand, the Sonoff power consumption is not measured, see http://tinkerman.cat/hlw8012-ic-new-sonoff-pow/#lightbox-gallery-NPLv/1/
  2. If the Sonoff is off there is no way the appliance can consume power, because the circuit is open
  3. In my Sonoff Pow with Tasmota, when the switch is OFF every indicator (current, voltage, watt, power factor) goes flat zero.
My suspect is of a software glitch. Do you have the latest Tasmota version?
5.0.7 Tasmota.
I have tried to flash the newest version, but each time have errors when compiling the code - missing files, etc. I have set the same config in the latest version as I have in 5.0.7.
You could use the “firmware upload” function and upload a compiled binary:
https://github.com/arendst/Sonoff-Tasmota/releases/download/v5.11.1/sonoff.bin
In tasmota 5.6 and 5.7 there are some fixes related to Sonoff Pow, maybe an update will resolve the glitch.
I’ve have tried this and the Sonoff became unresponsive, couldn’t access it via the webpage, or control it in any way. Even clicking the onboard button did nothing.
I’ve reflashed the old firmware again (5.0.7) to get it working. For some reason, I just can not seem to compile the newer version without getting constant errors.
Just post the errors. :wink: It will be a missing library usually.
Did you ever solve this? I’m using a POW R2 and have the same issue where the watts will spike, causing false washing machine alerts.
I’m using an average sensor:
switch:
  - platform: mqtt
    state_topic: "stat/sonoff-1663/POWER"
    command_topic: "cmnd/sonoff-1663/POWER"
    availability_topic: "tele/sonoff-1663/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: true
    optimistic: false
  - platform: statistics
    name: "sonoff1663 power stats"
    entity_id: sensor.sonoff1663_power
    sampling_size: 8
    max_age:
      minutes: 4
    sensors:
      energy_costs_total:
        friendly_name: Total costs
        value_template: "{{ (states.sensor.sonoff1663_energy_total.state|float * 0.30)|round(2) }}"
        unit_of_measurement: €
        icon_template: mdi:cash-100
  - platform: mqtt
    name: "sonoff1663 energy today"
    state_topic: "tele/sonoff-1663/SENSOR"
    value_template: '{{ value_json.ENERGY.Today }}'
    unit_of_measurement: "kWh"
  - platform: mqtt
    name: "sonoff1663 energy yesterday"
    value_template: '{{ value_json.ENERGY.Yesterday }}'
  - platform: mqtt
    name: "sonoff1663 energy total"
    value_template: '{{ value_json.ENERGY.Total }}'
  - platform: mqtt
    value_template: '{{ value_json.ENERGY.Power }}'
    unit_of_measurement: "W"
  - platform: mqtt
    value_template: '{{ value_json.ENERGY.Voltage }}'
    unit_of_measurement: "V"
  - platform: mqtt
    value_template: '{{ value_json.ENERGY.Current }}'
    unit_of_measurement: "A"
input_boolean:
  laundry_ready:
    icon: mdi:tshirt-crew
    initial: off
  laundry_hurled:
    icon: mdi:gauge-full
    initial: off
alert:
  laundry_ready:
    name: The laundry is ready!
    entity_id: input_boolean.laundry_ready
    state: 'on'
    repeat:
      - 15
      - 15
      - 30
      - 60
    can_acknowledge: true
    skip_first: false
    notifiers:
      - telegram_mobile
This is my automation:
automation:
  - alias: Turn off the laundry ready indicator
    initial_state: true
      - platform: state
        entity_id: switch.sonoff1663
        to: 'off'
      - service: homeassistant.turn_off
        entity_id: input_boolean.laundry_hurled
  - alias: Turn on the laundry ready indicator
    initial_state: true
      - platform: numeric_state
        entity_id: sensor.sonoff1663_power_stats_mean
        below: 7
        for:
          minutes: 2
    condition:
      condition: and
      conditions:
        - condition: state
          state: 'off'
        - condition: state
          state: 'on'
        - condition: state
          state: 'on'
      - service: homeassistant.turn_on
- alias: Turn on the laundry hurled indicator
  initial_state: true
      above: 200
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'off'
      - condition: state
        state: 'on'
# groups.yaml
sonoff1663:
  control: hidden
  entities:
    - switch.sonoff1663
    - sensor.sonoff1663_voltage
    - sensor.sonoff1663_power
    - sensor.sonoff1663_current
    - sensor.sonoff1663_energy_today
    - sensor.sonoff1663_energy_yesterday
    - sensor.sonoff1663_energy_total
    - sensor.energy_costs_total
    - sensor.sonoff1663_power_stats_mean
    - input_boolean.laundry_hurled
    - input_boolean.laundry_ready
