tom_l
December 3, 2019, 12:27pm
1
Before I go and flash this to one of my remaining Sonoff POW2s can anyone see anything particularly wrong with it?
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'WAPDI'
password: !secret wifi_pwd
manual_ip:
static_ip: 10.1.1.188
gateway: 10.1.1.1
subnet: 255.255.255.0
api:
password: !secret api_password
logger:
baud_rate: 0
uart:
rx_pin: RX
baud_rate: 4800
ota:
password: !secret esp_pwd
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
name: "Dining Heater N Power Button"
on_press:
- switch.toggle: relay
- platform: status
name: "Dining Heater N Status"
switch:
- platform: gpio
pin:
number: GPIO13
inverted: true
restore_mode: RESTORE_DEFAULT_ON
- platform: gpio
name: "Dining Heater N"
pin: GPIO12
icon: mdi:radiator
restore_mode: RESTORE_DEFAULT_OFF
- platform: restart
name: "Dining Heater N Restart"
- platform: wifi_signal
name: "Dining Heater N WiFi Signal"
update_interval: 15s
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
send_first_at: 1
icon: mdi:wifi
- platform: cse7766
current:
name: "Dining Heater N Current"
filters:
window_size: 10
send_every: 10
send_first_at: 1
voltage:
name: "Dining Heater N Voltage"
filters:
window_size: 10
send_every: 10
send_first_at: 1
power:
name: "Dining Heater N Power"
filters:
window_size: 10
send_every: 10
send_first_at: 1
- platform: total_daily_energy
name: "Dining Heater N Daily Energy"
power_id: dining_heater_n_wattage
filters:
- multiply: 0.001
window_size: 10
send_every: 10
send_first_at: 1
unit_of_measurement: kWh
icon: mdi:chart-bar
time:
- platform: homeassistant
paddy0174
(Patrick)
December 3, 2019, 1:03pm
2
Looks alright to me, but as I wrote in the Shelly EM thread, atm I’m just having Shelly1s.
You have sensors for power, voltage, current and wifi. Are there even more? I don’t think so.
Switch is ok, that I can say.
And the binary_sensor looks alright as well.
Do it!
moshe19803
(Moshe19803)
December 3, 2019, 6:38pm
3
tom_l:
sliding_window_moving_average: window_size: 15 send_every: 15 send_first_at: 1 icon: mdi:wifi - platform: cse7766 update_interval: 15s current: name: “Dining Heater N Current” filters: - sliding_window_moving_average: window_size: 10
this is what i have on 4 differnt pow2:
esphomeyaml:
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
wifi:
ssid: 'xxxxxx'
password: 'xxxx'
# manual_ip:
# Set this to the IP of the ESP
# static_ip: 192.168.1.232
# Set this to the IP address of the router. Often ends with .1
# gateway: 192.168.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
# subnet: 255.255.255.0
# Enable logging
logger:
baud_rate: 0
uart:
rx_pin: RX
baud_rate: 4800
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff pow2 Button"
on_press:
- switch.toggle: fakebutton
name: "Dryer Machine Running"
filters:
- delayed_off: 15s
lambda: |-
if (isnan(id(power).state)) {
return {};
} else if (id(power).state > 4) {
// Running
return true;
} else {
// Not running
return false;
switch:
name: "Sonoff pow2 Relay"
optimistic: true
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Sonoff pow2 Blue LED"
output: pow_blue_led
name: "Sonoff pow2 WiFi Signal"
update_interval: 60s
- platform: uptime
name: "Sonoff pow2 Uptime"
- platform: cse7766
update_interval: 2s
current:
name: "Sonoff pow2 Current"
voltage:
name: "Sonoff pow2 Voltage"
power:
name: "Sonoff pow2 Power"
on_value_range:
- above: 4.0
then:
- below: 3.0
then:
text_sensor:
- platform: version
name: "Sonoff pow2 ESPHome Version"
tom_l
December 4, 2019, 12:30am
4
Ok that worked well. The only thing I’m not completely happy with is having to poll the wifi connected LED. Other than using the status LED, can anyone think of a better way of doing it?
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'WAPDI'
manual_ip:
static_ip: 10.1.1.189
gateway: 10.1.1.1
api:
logger:
baud_rate: 0
uart:
rx_pin: RX
baud_rate: 4800
ota:
interval:
- interval: 10s
then:
if:
condition:
wifi.connected:
then:
- switch.turn_on: blue_led
else:
- switch.turn_off: blue_led
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
name: "Spare Bedroom Heater Power Button"
on_press:
- platform: status
name: "Spare Bedroom Heater Status"
switch:
- platform: gpio
pin:
number: GPIO13
inverted: true
- platform: gpio
name: "Spare Bedroom Heater"
pin: GPIO12
icon: mdi:radiator
- platform: restart
name: "Spare Bedroom Heater Restart"
name: "Spare Bedroom Heater WiFi Signal"
filters:
window_size: 15
send_every: 15
send_first_at: 1
icon: mdi:wifi
- platform: cse7766
current:
name: "Spare Bedroom Heater Current"
icon: mdi:current-ac
filters:
window_size: 10
send_every: 10
send_first_at: 1
voltage:
name: "Spare Bedroom Heater Voltage"
icon: mdi:flash
filters:
window_size: 10
send_every: 10
send_first_at: 1
power:
name: "Spare Bedroom Heater Power"
icon: mdi:gauge
filters:
on_value_range:
- above: 4.0
then:
- below: 3.0
then:
name: "Spare Bedroom Heater Daily Energy"
power_id: spare_bedroom_heater_wattage
filters:
- multiply: 0.001
icon: mdi:chart-bar
time:
