Hello Guys,
I thing this is a simple question which already use sonoff but for me is that to difficult.
What i have;
- Sonoff mini with tasomta -> connected on the Ceiling and the bulb connected to sonoff mini.
- I have a normal wall Switch.
Question: I need, when i use the normal switch and turn on, i will always that the bulp turn on wherever it is turned OFF via Home Assistant.
It is now so when i turned off the sonoff via Home Assistant and turn on via normal wall switch the bulb will go on and after 4 seconds it is gooing off.
Current config file"
platform: mqtt
state_topic: “stat/xxx/POWER”
command_topic: “cmnd/xxx/POWER”
qos: 0
optimistic: false
payload_on: “ON”
payload_off: “OFF”
payload_available: “Online”
payload_not_available: “Offline”
retain: true
Just needed:
1. Via normal wall switch bulbs always be turned ON by turning on the Wall switch.
2. Update the status on Home Assistant as bulp “turned off” when turned off via wall switch.
