Hello All!
My problem is that I can not make a binary sensor to work for the Sonoff R4 mini smart switch. If i use this wiring everything is fine, i can see the switching binary entity in home assistant using the GPIO27 when i short S1 and S2 with a wire (picture on the left, the working one): https://cdn.cnx-software.com/wp-content/uploads/2023/02/SONOFF-MINIR4-Wiring-instructions-720x436.jpg?lossy=1&ssl=1
But my bathroom is wired like here: https://europe1.discourse-cdn.com/standard21/uploads/ewelinkforum/original/2X/f/f8e778bf8f9dedb31906e7f3cf0da16c447d6f15.jpeg
In this case the binary swithc does not work, its always in off state, despite i use the same config file.
The device is flashed with esp32dev by Espressif Firmware: 2023.8.3
In this case when i turn on the physical wall mounted switch (live wire on, like in the second wiring picture) nothing happens.
Thanks in advance. by the way the config is:
substitutions:
display_name: "minir4-esph"
esphome:
esp32:
board: esp32dev
framework:
type: arduino
wifi:
ssid: !secret wifi_ssid
ap:
ssid: ${display_name}_AP
ap_timeout: 3min
captive_portal:
esp32_ble_tracker:
scan_parameters:
interval: 300ms
window: 100ms
active: true
bluetooth_proxy:
active: true
logger:
ota:
api:
switch:
- platform: gpio
pin:
number: GPIO26
inverted: false
on_turn_on:
- light.turn_on: relay_led
on_turn_off:
- light.turn_off: relay_led
- platform: restart
output:
- platform: gpio
pin: GPIO19
inverted: True
light:
- platform: binary
internal: true
output: relay1_led_gpio
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO27
mode: INPUT_PULLUP
inverted: false
on_state:
- switch.toggle: relay
- platform: gpio
internal: true
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: false
on_press:
- platform: gpio
name: "device phase is on"
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: false
internal: false
- platform: gpio
pin:
number: GPIO27
mode: INPUT_PULLUP
inverted: false
internal: false
