I implemented the demux strategy using node-red.
Features
- Home Assistant Discovery
- Sensor Learning for motion and door
- File-based Yaml configuration w/ autosave and autoload on node-red restart.
Here is the main demux code that I am using. It’s a little messy right now
var result = {}
const regex = /(.{5})([7BEF])$/;
const sensor_topics = msg.sensors;
const states = {
'7': 'close',
'E': 'open',
'F': 'battery',
'B': 'tamper'
var data = msg.payload.RfReceived.Data;
var sensor
if (regex.test(data)) {
var matches = regex.exec(data);
sensor = sensor_topics[matches[1]];
} else {
sensor = sensor_topics[data]
if (typeof sensor !== "undefined") {
if (sensor.class == 'door' && matches.length == 3 ) {
var state = states[matches[2]];
switch (state) {
case 'battery':
result = {
topic: `${sensor.topic}/battery`,
payload: 1,
retain: false
break;
case 'tamper':
result = {
topic: `${sensor.topic}/tamper`,
payload: 1,
retain: false
break;
default:
result = {
topic: `${sensor.topic}/state`,
payload: states[matches[2]],
retain: sensor.retain
result.error = null
} else {
result = {
payload: 1,
retain: false
result.error = null
} else {
result.error = {
message: `Unknown Sensor ${data}`,
code: data
return result;
