Hi Guys
I have a Sonoff RF Bridge flashed with Tasmota and working fine. I just bought a new 433mhz door sensor however when I open / close door sensor , the code does not reflect in the Tasmota console ? Its a 433mhz sensor ?
Any reason why the RF bridge is not seeing the door sensor even though they close together.
Sonoff RF bridge only picks up certain 433Mhz signals, and it is very limited. If you have a device that is not being picked up, then you need to flash the RF chip in the bridge with the Portisch firmware.
GitHub - Portisch/RF-Bridge-EFM8BB1: Alternative Firmware for the Sonoff RF Bridge EFM8BB1 chip
Please note that this firmware is the firmware of the RF chip only, not the device itself. You still use Tasmota for the device.
Personally, I try to buy devices that use EV1527 encoding.
Hi
Thanks for advice, can you advise a Device that supports EV1527, would this find the majority 433Mhz devices ?
Hi, all the devices below identified with a compatible modules = SRFB are compatible with Sonoff RFBridge without changing the EFM8BB1 firmware (the communication module chip):
particularly the low-cost chinese ones.
The 2 possibilities for extending the RF Bridge compatibilities are:
- Direct hack, requires good soldering competencies
- Flashing the EFM8BB1 as suggested above
The direct hack enables to support these protocols through Pilight
The EFM8BB1 flash enables to support this list of protocols
Door/window sensors that support different codes for open, close and low battery - 1/3/6/10pcs Wireless Door Window Sensor 433Mhz Magnet Detector Wifi Door Opening Sensor for G90B Plus Home Security Alarm System|Sensor & Detector| - AliExpress
Physical switches used to toggles - VHOME Smart Home RF 433MHz 3Gang Wireless Switch Shape Remote Control for Touch Wall Lightes Electric Curtains,Home Automation|remote control|remote control controllercontrol remote - AliExpress
If you are purchasing through AliExpress or BangGood, then include “EV1527” in your search.
Hi @aheath how do you manage a group of these door sensors?
With zigbee ones you can rename each entity but what about the rf 433mhz version? Do each of them comes with discrete signal?
Each device sends out a discrete code. I am not sure how this code is derived, but I only have a few devices so the chances of a clash is low. I personally use NodeRed and I have writeen a flow which listens for RF signals on my Sonoff RF Bridge which us running Tasmota. The flow checks for the codes that each device emits and branches off accordingly.
