A year or two ago I got sonoff rf bridge (black box, model says just “RF Bridge”). Finally got to “deploy” it. Flushed recent tasmota (generic tasmota.bin
) on it using tasmotizer while following some generic instructions on howto via USB, chose
But for the door sensor, I get only one type of event (Data
is the same), so can’t tell when “opens” vs “closes”, and seems not consistently really:
15:18:40.526 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:18:40","RfReceived":{"Sync":7970,"Low":270,"High":790,"Data":"D18651","RfKey":"None"}}
15:18:50.870 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:18:50","RfReceived":{"Sync":7960,"Low":280,"High":780,"Data":"D18651","RfKey":"None"}}
15:18:59.323 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:18:59","RfReceived":{"Sync":7940,"Low":280,"High":780,"Data":"D18651","RfKey":"None"}}
15:19:17.258 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:19:17","RfReceived":{"Sync":7980,"Low":270,"High":790,"Data":"D18651","RfKey":"None"}}
The sensor is ATM very close (1ft) to RF bridge.
any guidance/clues on what to do to get it reliably detect events?
Fuller log after reboot:
00:00:00.001 HDW: ESP8285N08
00:00:00.050 CFG: Loaded from flash at F5, Count 55
00:00:00.055 SER: Set to 8N1 19200 bit/s
00:00:00.056 QPC: Count 1
00:00:00.067 SER: Set to 8N1 19200 bit/s
00:00:00.070 Project tasmota - tasmota-rf-bridge Version 14.4.1(release-tasmota)-2_7_8(2024-12-15T13:29:54)
00:00:01.001 WIF: Connecting to AP1 ESCAPE-HA Channel 7 BSSId 08:BF:B8:4D:FA:43 in mode 11g as tasmota-sonoff-7889...
00:00:02.586 WIF: Connected
00:00:02.838 HTP: Web server active on tasmota-sonoff-7889 with IP address 192.168.3.6
15:25:03.634 MQT: Attempting connection...
15:25:04.097 MQT: Connect failed to 192.168.2.2:1883, rc -2. Retry in 10 sec
15:25:06.112 QPC: Reset
15:25:14.872 MQT: Attempting connection...
15:25:15.014 MQT: Connected
15:25:15.017 MQT: tele/tasmota_sonoff/LWT = Online (retained)
15:25:15.019 MQT: cmnd/tasmota_sonoff/POWER =
15:25:15.025 MQT: tele/tasmota_sonoff/INFO1 = {"Info1":{"Module":"Sonoff Bridge","Version":"14.4.1(release-tasmota)","FallbackTopic":"cmnd/DVES_EE1ED1_fb/","GroupTopic":"cmnd/tasmotas/"}}
15:25:15.032 MQT: tele/tasmota_sonoff/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-sonoff-7889","IPAddress":"192.168.3.6"}}
15:25:15.038 MQT: tele/tasmota_sonoff/INFO3 = {"Info3":{"RestartReason":"Power On","BootCount":16}}
15:25:16.459 MQT: stat/tasmota_sonoff/STATUS1 = {"StatusPRM":{"Baudrate":19200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota/release/tasmota.bin.gz","RestartReason":"Power On","Uptime":"0T00:00:18","StartupUTC":"2025-02-24T14:24:58","Sleep":50,"CfgHolder":4617,"BootCount":15,"BCResetTime":"2025-02-17T04:46:40","SaveCount":57,"SaveAddress":"FB000"}}
15:25:16.509 MQT: stat/tasmota_sonoff/STATUS11 = {"StatusSTS":{"Time":"2025-02-24T15:25:16","Uptime":"0T00:00:18","UptimeSec":18,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"Wifi":{"AP":1,"SSId":"ESCAPE-HA","BSSId":"08:BF:B8:4D:FA:43","Channel":8,"Mode":"11g","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}}
15:25:19.069 MQT: tele/tasmota_sonoff/STATE = {"Time":"2025-02-24T15:25:19","Uptime":"0T00:00:21","UptimeSec":21,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"ESCAPE-HA","BSSId":"08:BF:B8:4D:FA:43","Channel":8,"Mode":"11g","RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:26:12.165 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:26:12","RfReceived":{"Sync":7970,"Low":270,"High":790,"Data":"D18651","RfKey":"None"}}
15:26:22.325 MQT: tele/tasmota_sonoff/RESULT = {"Time":"2025-02-24T15:26:22","RfReceived":{"Sync":7970,"Low":270,"High":790,"Data":"D18651","RfKey":"None"}}
