I managed to flash the firmware so I can perform OTA updates. Does anyone have any yaml for setting this up to work with ESPHome and HA?
Explained here
Here is my YAML for the Sonoff S31 running my Yard Lights. In addition to the Power Sensors, it is set to turn on the Lights at Sunset and off at 3 AM.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'Your SSID'
password: 'Your Password'
# Optional manual IP
manual_ip:
static_ip: 192.168.x.x
gateway: 192.168.x.x
subnet: 255.255.255.0
# Enable logging
logger:
baud_rate: 0
uart:
rx_pin: RX
baud_rate: 4800
# Enable Home Assistant API
api:
ota:
time:
- platform: homeassistant
on_time:
# 3 AM Daily
- hours: 3
then:
- switch.turn_off: relay
- light.turn_off: led
sun:
latitude: 34.327778
longitude: -118.640644
on_sunset:
- then:
- switch.turn_on: relay
- light.turn_on: led
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: fakebutton
filters:
- delayed_off: 15s
lambda: |-
if (isnan(id(power).state)) {
return {};
} else if (id(power).state > 4) {
// Running
return true;
} else {
// Not running
return false;
switch:
name: "Yard POW Relay"
optimistic: true
turn_on_action:
turn_off_action:
- platform: gpio
pin: GPIO12
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Yard Blue LED"
output: pow_blue_led
- platform: wifi_signal
name: "Yard WiFi Signal"
update_interval: 60s
- platform: uptime
- platform: cse7766
update_interval: 2s
current:
voltage:
power:
name: "Yard POW Power"
on_value_range:
- above: 4.0
then:
- below: 3.0
then:
text_sensor:
- platform: version
name: "Yard ESPHome Version"
- platform: sun
name: Sun Next Sunrise
type: sunrise
format: "%I:%M %p"
- platform: sun
name: Sun Next Sunset
type: sunset
format: "%I:%M %p"
