Sonoff S31 Outlet with ESPHome - Example YAML
EDIT: The YAML has changed over time as I make improvements and corrections. I am not rewriting this post as for the most part it is still correct (if not let me know) but keep in mind the YAML at the bottom of the post has evolved a bit compared to what you see in this first post.
I found a basic version of the code below for the Sonoff S31 and made a number of improvements, at least for my use scenario. I rely a lot on people sharing so I wanted to share back in case it helps others. I had started off with Tasmota and really liked the fact the outlet had a web interface and how much information was available for each device. What I did not like was the complexity of setting it all up due to MQTT being in the middle. It was not difficult but it felt unnecessarily complicated when ESPHome has a more direct integration. Anyway this thread is not meant o be a debate between ESPHome and Tasmota so back to the YAML:
This is the entire code needed:
substitutions:
  devicename: s31-outlet-1
  friendly_devicename: "Office Equipment Outlet"
# Basic Config
esphome:
  platform: ESP8266
  board: esp01_1m
The substitutions section allows to define variables so that you don’t have to edit the YAML in many places each time you create a new device using this YAML or simply make a change.
The devicename needs to be short and a unique identifier. I would set it, and leave it, named as you named the configuration in ESPHome when you created the device. For some reason I run into issues (device not found, etc.) if I mess with it. This is also how this device will be named on the Integration page under ESPHome (but you can rename it there if you really want to), and will be the default device name in Home Assistant (which we will change).
The friendly_devicename is what you will call the device. This device is an outlet so I would recommend naming it with the name of the device attached to the outlet, or blah blah outlet in the event the outlet is powering has multiple devices. This is important as it will determine what all the other entities will be named and will save you lots of entity editing later.
wifi:
  ssid: !secret iot_wifi_ssid
  password: !secret iot_wifi_password
  ap:
    ssid: "${devicename} Hotspot"
When you see !secret it is referring to a variable in your secrets.yaml file which can be edited directly from within ESPHome (top right of window). Just add the following editing in your details:
# Your IOT Wi-Fi SSID and password
iot_wifi_ssid: "IoT_ SSID_ here"
iot_wifi_password: "password_here"
I really wanted to see some device information when loading up the IP of the device in a web browser like Tasmota. While not as fancy, a lot can be shown on ESPDevices just by adding a few lines of YAML. I don’t know what include_internal: true actually does as I don’t believe I saw a difference with or without it, but it doesn’t seem to be causing issues so I left it.
web_server:
  port: 80
Whether needed or not, I wanted to see all connectivity variables as entities for easier troubleshooting. When you start having lots of devices this is handy. Here we see the ${friendly_devicename} variable which will give the entities a name that includes the device name.
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: "mdi:ip-outline"
    ssid:
      icon: "mdi:wifi-settings"
    bssid:
    mac_address:
      icon: "mdi:network-outline"
    scan_results:
      name: "${friendly_devicename}: Wifi Scan"
      icon: "mdi:wifi-refresh"
      disabled_by_default: true
This is how it will look in HA:
In the example above, only IP will appear on the device page but on a dashboard it will sow as Office Equipment Outlet: IP.
Same thing for the Controls and Sensors of the device. In the sensor section I changed the Energy over time from W (which I believe was showing with 3 decimals which was a bit silly) to kW with 3 decimals. I would argue that seeing anything under 1W is really meaningless and probably not even very accurate for this kind of device. If you set it to kW the numbers will be smaller and you will still see down to the 1W granularity. For those wanting to figure out the cost of the power used, this makes it a tiny bit simpler since power is sold by the kWh. Before this change, 2.345kW was showing as 2,345.678W. I would argue that the 1 decimal accuracy for voltage and power are also pointless but I left them since almost all other devices show that or more.
  - platform: wifi_signal
    name: "${friendly_devicename}: WiFi Signal"
    update_interval: 60s
  - platform: cse7766
    current:
      accuracy_decimals: 1
    voltage:
    power:
  - platform: total_daily_energy
    name: "${friendly_devicename}: Daily Energy"
    power_id: my_power
    filters:
      # Multiplication factor from W to kW is 0.001
      - multiply: 0.001
    unit_of_measurement: kW
No changes here, but I believe the restore_mode: ALWAYS_ON is what makes the outlet turn on immediately after being powered up.
switch:
  - platform: gpio
    icon: "mdi:power-socket-us"
    pin: GPIO12
If this doesn’t work for you, the other options should be here:
I have not tested these yet, but the page above lists these as options:
* **restore_mode** (*Optional*): Control how the GPIO Switch attempts to restore state on bootup. For restoring on ESP8266s, also see `restore_from_flash` in the [esp8266 section](https://esphome.io/components/esp8266.html).
> * `RESTORE_DEFAULT_OFF` (Default) - Attempt to restore state and default to OFF if not possible to restore.
>   * `RESTORE_DEFAULT_ON` - Attempt to restore state and default to ON.
>   * `RESTORE_INVERTED_DEFAULT_OFF` - Attempt to restore state inverted from the previous state and default to OFF.
>   * `RESTORE_INVERTED_DEFAULT_ON` - Attempt to restore state inverted from the previous state and default to ON.
>   * `ALWAYS_OFF` - Always initialize the pin as OFF on bootup.
>   * `ALWAYS_ON` - Always initialize the pin as ON on bootup.
I read this part is needed if you want the energy measurement kWh to be reset daily. In most cases you either need a time/date from the start of the measurement, or just reset it daily. I would like a start time/date as Tasmota offered and a way to reset it as needed. I’ll research this to see if it is possible from within the device YAML itself.
time:
  - platform: sntp
:point_right::point_right::point_right: Full YAML you can try here: :point_left::point_left::point_left:
:point_right: Edit: see further down for updated full YAML
substitutions:
# Basic Config
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ap:
logger:
  baud_rate: 0 # (UART logging interferes with cse7766)
# Remove this line if you're not using Home Assistsant or your switch will restart every now and again
api:
ota:
web_server:
  port: 80
# Device Specific Config
uart:
  rx_pin: RX
  baud_rate: 4800
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - switch.toggle: relay
  - platform: status
  - platform: cse7766
    current:
    voltage:
    power:
    power_id: my_power
    filters:
      - multiply: 0.001
switch:
  - platform: gpio
    pin: GPIO12
time:
  - platform: sntp
status_led:
  pin: GPIO13
Thank you to all those who have helped me on HA stuff! I hope this counts as giving back a little :slight_smile:
Disclaimer: As mentioned above, I found most of this code online (sorry I forgot where) and just customized it a bit. Not claiming any authorship!
I would now add the device leaving the name that matches what it is called in ESPHome. Once added, go to the device to make one last change. There I would only change the device name on the top left to match what you used in the friendly_devicename variable. In the example above it is Office Equipment Outlet. Doing so will make your device page look like this without further editing:
Most of the time I end up having to edit every single entity for it to be named following what I adopted as my standard. With this YAML I don’t and it has become much easier to add/remove. In fact, if you end up with other entities under this device that you want to get rid of (I did while making changes), just delete it from the ESPHome Integration (only the integration!!!) and add it back (Add integration, select ESPHome, and enter IP).
The only entity that I set as disabled by default is the Wifi Scan one that shows all the APs it receives. It’s unnecessary in most cases… you may want it only if you have connectivity issues and want to see what it receives.
This is how it will show up in ESPHome… too bad one can’t add a descriptor.
Last, the web interface (default view)…
:point_right::point_right::point_right: LATEST VERSION OF THE FULL YAML :point_left::point_left::point_left:
UPDATED: 05-JUL-2022
For information on changes please refer to the posts in this thread.:
Deprecated YAML - Expand section to see it
substitutions:
  devicename_no_dashes: s31_outlet_1
  restore_mode_setting: RESTORE_DEFAULT_ON
  #restore_mode: Control how the relay attempts to restore state on bootup.
  #RESTORE_DEFAULT_OFF          - Attempt to restore state and default to OFF if not possible to restore.
  #RESTORE_DEFAULT_ON           - Attempt to restore state and default to ON.
  #RESTORE_INVERTED_DEFAULT_OFF - Attempt to restore state inverted from the previous state and default to OFF.
  #RESTORE_INVERTED_DEFAULT_ON  - Attempt to restore state inverted from the previous state and default to ON.
  #ALWAYS_OFF                   - Always initialize the pin as OFF on bootup.
  #ALWAYS_ON                    - Always initialize the pin as ON on bootup.
# Basic Config
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ap:
logger:
api:
ota:
web_server:
  port: 80
uart:
  rx_pin: RX
  baud_rate: 4800
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
  - platform: status
  - platform: cse7766
    current:
      state_class: measurement
      device_class: current
      unit_of_measurement: A
    voltage:
      device_class: voltage
      unit_of_measurement: V
    power:
      device_class: power
      unit_of_measurement: W
    power_id: "${devicename_no_dashes}_power"
    filters:
      - multiply: 0.001
    state_class: total_increasing
    device_class: energy
    # 3 shows each W consumed, 2 every 10W, 1 every 100W
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: ${restore_mode_setting}
time:
  - platform: sntp
status_led:
  pin: GPIO13
UPDATED: 07-MAR-2024
For information on changes please refer to this post in this thread.:
template-s31-outlet.yaml
Note: placed in same folder as all other ESPHome YAML files, although there is a way to hide it, I prefer not to.
  # Basic Config
  esphome:
    comment: ${device_description}
    friendly_name: ${friendly_devicename}
  esp8266:
    board: esp01_1m
    early_pin_init: false #This prevents the on-off-on of the relay upon firmware upload
  logger:
  api:
  ota:
  web_server:
    port: 80
  # Sync time with Home Assistant
  # Used to calculate total daily energy
  time:
    - platform: homeassistant
  uart:
    rx_pin: RX
    baud_rate: 4800
  text_sensor:
      ip_address:
        update_interval:  ${update_interval_wifi}
      ssid:
      bssid:
      mac_address:
      scan_results:
  binary_sensor:
    #Status Binary Sensor exposes the node state (if it’s connected to via MQTT/native API) for Home Assistant.
    - platform: status
      entity_category: diagnostic
    - platform: gpio
      pin:
        number: GPIO0
        mode: INPUT_PULLUP
        inverted: True
      entity_category: ''
      on_press:
          then:
            - if:
                condition: # only toggle relay if button is enabled
                  lambda: 'return (id(select_button).state == "Enabled");'
                then:
      name: "Above Threshold"
    #https://esphome.io/components/sensor/cse7766.html
    - platform: cse7766
      current:
        filters:
          - throttle: ${cse7766_throttle_interval}
      voltage:
        filters:
          - offset: ${voltage_cal}
      power:
        device_class: power
        filters:
        on_value:   # set or clear threshold_status template binary sensor depending on whether power usage is over threshold
          - if:
              condition:
                lambda: 'return (x >= id(power_threshold).state);'
              then:
                - binary_sensor.template.publish:
                    state: ON
                - if:               # set or clear threshold_status template binary sensor depending on whether power usage is above threshold
                    condition:
                      lambda: 'return (id(select_led).state == "Threshold");'
                    then:
                      - switch.turn_on: blue_led
              else:
                    state: OFF
                    condition:
                    then:
                      - switch.turn_off: blue_led
      power_id: power
      filters:
        - multiply: 0.001
      unit_of_measurement: kWh
      #lambda: return id(power).state / id(voltage).state / id(current).state;
      lambda: |-
        auto x = id(power).state / id(voltage).state / id(current).state;
        if (x >= 0) return x;
            return 0.0;
  number:      # used as a threshold for whether the plugged-in devices is running.
      name: "Power Threshold"
      min_value: 1
      max_value: 1800
      step: 1
      initial_value: 3
      entity_category: config
      optimistic: true     # required for changing value from home assistant
      restore_value: true
      mode: box
      on_value:
        - if:
            condition:
              lambda: 'return (id(power).state >= x);'
            then:
                  state: ON
              - if:
                  condition:
                  then:
            else:
                  state: OFF
              - if:
                  condition:
                  then:
  switch:
      # blue LED follows relay power state
    - platform: gpio
      pin:
        number: GPIO13
        inverted: true
      # relay output
    - platform: gpio
      pin: GPIO12
      entity_category: ''
      # automatically make blue led equal relay state if set to "Relay"
      on_turn_on:
        - if:
            condition: # only if blue LED set to "Relay"
              lambda: 'return (id(select_led).state == "Relay");'
            then:
      on_turn_off:
        - if:
            then:
  #Do not enable otherwise Blue led can't be configured
  #status_led:
  #    pin:
  #      number: GPIO13
  button:
    - platform: restart
  select:
      # option to disable button
      optimistic: true
      options:
        - Enabled
        - Disabled
      initial_option: Enabled
      restore_value: true
      icon: mdi:circle-double
      # option to disable blue LED
      optimistic: true
      options:
        - Relay
        - Threshold
        - Disabled
      initial_option: Relay
      restore_value: true
      icon: mdi:led-on
      on_value:
        then:
        - if:
            condition:
              lambda: 'return ( (id(select_led).state == "Relay") && id(relay).state );'
            then:
            else:
Device specific YAML:
office-equipment-outlet.yaml
substitutions:
  devicename: "office-equipment-outlet"
  device_description: "Office Equipment Outlet - s31_outlet_1"
  voltage_cal: "0.5"
  restore_mode_setting: ALWAYS_ON
  #RESTORE_DEFAULT_ON           - Attempt to restore state and default to ON if not possible to restore.
  # Interval of how often the wifi info is updated
  update_interval_wifi: "60s"
  cse7766_throttle_interval: "5s"
wifi:
  # Default 15min, 0s will disable. Disabling because w/HA down the relays cycle on/off every 15 minutes.
  reboot_timeout: 0s
  ap:
    ssid: "${devicename}"
#Faster than DHCP. Also use if can't reach because of name change
  manual_ip:
    static_ip: 10.1.3.170
    gateway: 10.1.2.1
    subnet: 255.255.254.0
    dns1: 10.1.0.50
    dns2: 10.1.0.51
#Manually override what address to use to connect to the ESP.
#Defaults to auto-generated value. Example, if you have changed your
#static IP and want to flash OTA to the previously configured IP address.
  use_address: 10.1.3.170
<<: !include template-s31-outlet.yaml
UPDATED: 29-JUL-2024
For the YAML and information on changes please refer to this post in this thread.:
Thanks for setting this up @aruffell. I just got a few of these outlets and I used this template to get them quickly into HA. I had some trouble getting it recognized by the Energy dashboard so I made some edits to the sensor section. All is good now. If you find it helpful feel free to include them in your template (I changed devicename substitutions variable so it would require an edit to the below).
  - platform: cse7766
    current:
    voltage:
    power:
    power_id: "${s31_outlet_1}_power"
    filters:
      - multiply: 0.001
@techanti Awesome! Thank you! I incorporated most of your edits and had a question about a couple.
I see that you declared Current, Voltage, Power as entity_category: diagnostic but I don’t believe that to be appropriate based on the definition here:
Is there a particular reason for doing so?
Were all the other…
unit_of_measurement: x
…needed for the sensor to be usable in the Energy dashboard?
I included your changes, albeit modified, for the power ids (id & power_id). Do they need to be unique thus prompting the change? My modification to what you did just pushes the edit to the top and will require just one edit.
This is what the full code looks like now:
substitutions:
# Basic Config
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ap:
logger:
api:
ota:
web_server:
  port: 80
uart:
  rx_pin: RX
  baud_rate: 4800
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
  - platform: status
  - platform: cse7766
    current:
    voltage:
    power:
    filters:
      - multiply: 0.001
switch:
  - platform: gpio
    pin: GPIO12
time:
  - platform: sntp
status_led:
  pin: GPIO13
I have changed restore_mode: ALWAYS_ON to restore_mode: RESTORE_DEFAULT_ON as I believe it is what most people would likely prefer (and it is easy to change anyway). I also moved the setting up top to make it easier to spot and edit.
As I understand things, The class and unit of measure have to be set for them be usable in the Energy dashboard. entity_category comes from the entity definition below and I usually have it on the esphome things I do while I working on them but often neglect to remove it:
https://developers.home-assistant.io/docs/core/entity/#generic-properties
Again, thanks of for this. It save me a lot time.
@techanti - I found errors in the “Statistics” section stating that "The unit (“W”) of this entity doesn’t match a unit of device class ‘energy’.
I checked and found that the device_class for Power (W) should be “power” and not “energy” so I made the correction and updated the code in my first post (at the bottom).
Thank you for the config example, this helped getting the base configuration running but I noticed the sensors were sending far to much spam. I refined the update intervals on the sensors to only receive useful updates - update the filter delays as you see fit.
uart:
  rx_pin: RX
  baud_rate: 4800
text_sensor:
    ip_address:
    ssid:
    bssid:
    mac_address:
    scan_results:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
  - platform: status
  - platform: cse7766
    current:
      filters:
        - throttle_average: 5s
        - delta: 0.1
    voltage:
      filters:
        - throttle: 30s
    power:
      filters:
        - throttle: 30s
        - delta: 0.1
    filters:
      - throttle: 60s
      - multiply: 0.001
switch:
  - platform: gpio
    pin: GPIO12
time:
  - platform: sntp
status_led:
  pin: GPIO13
@david-fuchs I have made several changes since I last posted the YAML, and one of them was to throttle the measurements but in a more basic way than yours. In this example it is still set at 5s which is way too often for most use cases.
Also, since I have a 10+ of these outlets and got fed up making changes to all of them, I split the YAML into a template and a device specific file.
Sharing for reference:
Note: placed in same folder as all other ESPHome YAML files, although there is a way to hide it, I prefer not to. You don’t compile or upload this one. It gets pulled in by the device specific file. Note that there are 2 extra spaces at the beginning of each line otherwise the import won’t work.
  # Basic Config
  esphome:
  esp8266:
    board: esp01_1m
  logger:
  api:
  ota:
  web_server:
    port: 80
  time:
  uart:
    rx_pin: RX
    baud_rate: 4800
  text_sensor:
      ip_address:
      ssid:
      bssid:
      mac_address:
      scan_results:
  binary_sensor:
    - platform: status
    - platform: gpio
      pin:
        number: GPIO0
        mode: INPUT_PULLUP
        inverted: True
      entity_category: ''
      on_press:
          then:
            - if:
                then:
    - platform: cse7766
      current:
        filters:
      voltage:
        filters:
      power:
        device_class: power
        filters:
          - if:
              condition:
              then:
                    state: ON
                    condition:
                    then:
              else:
                    state: OFF
                    condition:
                    then:
      power_id: power
      filters:
        - multiply: 0.001
      lambda: |-
            return 0.0;
      min_value: 1
      max_value: 1800
      step: 1
      initial_value: 3
      restore_value: true
      mode: box
      on_value:
        - if:
            condition:
            then:
                  state: ON
              - if:
                  condition:
                  then:
            else:
                  state: OFF
              - if:
                  condition:
                  then:
  switch:
    - platform: gpio
      pin:
        number: GPIO13
        inverted: true
      # relay output
    - platform: gpio
      pin: GPIO12
      entity_category: ''
      on_turn_on:
        - if:
            then:
      on_turn_off:
        - if:
            then:
  #status_led:
  #    pin:
  #      number: GPIO13
  button:
    - platform: restart
  select:
      optimistic: true
      options:
        - Enabled
        - Disabled
      restore_value: true
      optimistic: true
      options:
        - Relay
        - Threshold
        - Disabled
      restore_value: true
      icon: mdi:led-on
      on_value:
        then:
        - if:
            condition:
            then:
            else:
substitutions:
  voltage_cal: "0.5"
wifi:
  reboot_timeout: 0s
  ap:
  manual_ip:
    gateway: 10.1.2.1
    dns1: 10.1.0.50
    dns2: 10.1.0.51
Maybe the most important modification is:
As it prevents the super annoying relay toggling when you upload the firmware which essentially turns the outlet off… turning off whatever is connected to it. For some devices it is not an issue, but certainly is for others…
Edit: I found the post I’d like to credit for the early_pin_init fix as it made a world of difference: Sonoff S31 Outlet running ESPHome - Any way to prevent relay cycling (on>off>on) after firmware upload? - #12 by orange-assistant
Thank you! I’m in the same boat - have 10+ of these units also. Great idea on the template for the config.
How do I add this to the built in Home Assistant Energy usage, as it seams this only totals up daily energy usage, which is not how the energy usage on HA works, I would need power produced because I believe it adds energy usage by itself and use that to add it to the energy usage page.
Amazing work! I agree that creating a template is the way to go. Is it possible to add the restore state variable to be visible in HA?
Below I am sharing the current version of the YAML I am using for the S31 outlets. It has not changed too much from the original posted above but has been adjusted to work with the latest changed in ESPHome.
@nosar7 - I modified the code to add the regular energy sensor and a couple others that I had missed or maybe were added after I finished working on the YAML. Either way you should now have what you seek.
If you want to adjust it in any way, here are a couple pages that might help:
@MatthewCMason - Unfortunately I do not know of any way to add the restore state configuration to the UI. If anyone does, please let me know!
One of the sensor I added, based on the cse7766 page referenced above is the Power Factor which prior I was calculating with a lambda. They both gave the same number so I just removed my template in favor of the baked in support… anyhow now I see an error in the logs:
[09:00:33][D][cse7766:186]: Impossible power factor: 1.0110 not in interval [0, 1]
Not a big deal but I wonder why…
Also, another minor issue is that the switch entity will show in the UI without a name. This is due to how I set up the YAML to force the naming of the entities (both internal and UI facing) to I want them to be. In other words, if the device is called “Office Equipment Outlet”, I want the switch entity to have the same name and I want the internal entity to also reflect that as in switch.office_equipment_outlet. Without my workaround it would end up being something like switch.office_equipment_outlet_office_equipment_outlet. Without the workaround the fix is just to rename the entity id, and with the workaround, it is simply to copy the device name and paste it into the entity name. This issue started once friendly_name was introduced eliminating the need to prepend it to each entity. Hopefully this makes sense…
substitutions:
  device_description: "Office Equipment Outlet - s31-outlet-1"
  voltage_cal: "0.5"
  update_interval_wifi: "120s"
  cse7766_throttle_interval: "60s"
wifi:
  reboot_timeout: 0s
  ap:
  manual_ip:
    gateway: 10.1.2.1
    dns1: 10.1.0.50
    dns2: 10.1.0.51
Template YAML common to all S31 outlets you have:
  esphome:
  esp8266:
    board: esp01_1m
  logger:
  api:
  ota:
    - platform: esphome
      #password: !secret ota_password
  web_server:
    port: 80
  time:
  uart:
    rx_pin: RX
    baud_rate: 4800
  text_sensor:
      ip_address:
      dns_address:
        icon: "mdi:dns-outline"
      ssid:
      bssid:
      mac_address:
      scan_results:
  binary_sensor:
    - platform: status
    - platform: gpio
      pin:
        number: GPIO0
        mode: INPUT_PULLUP
        inverted: True
      entity_category: ''
      on_press:
          then:
            - if:
                then:
    - platform: cse7766
      current:
        filters:
          - throttle_average: ${cse7766_throttle_interval}
      voltage:
        filters:
      power:
        device_class: power
        filters:
          - if:
              condition:
              then:
                    state: ON
                    condition:
                    then:
              else:
                    state: OFF
                    condition:
                    then:
      energy:
        filters:
      apparent_power:
        filters:
      power_factor:
        filters:
      power_id: power
      filters:
        - multiply: 0.001
      min_value: 1
      max_value: 1800
      step: 1
      initial_value: 3
      restore_value: true
      mode: box
      on_value:
        - if:
            condition:
            then:
                  state: ON
              - if:
                  condition:
                  then:
            else:
                  state: OFF
              - if:
                  condition:
                  then:
  switch:
    - platform: gpio
      pin:
        number: GPIO13
        inverted: true
      # relay output
    - platform: gpio
      pin: GPIO12
      entity_category: ''
      on_turn_on:
        - if:
            then:
      on_turn_off:
        - if:
            then:
  #status_led:
  #    pin:
  #      number: GPIO13
  button:
    - platform: restart
  select:
      optimistic: true
      options:
        - Enabled
        - Disabled
      restore_value: true
      optimistic: true
      options:
        - Relay
        - Threshold
        - Disabled
      restore_value: true
      icon: mdi:led-on
      on_value:
        then:
        - if:
            condition:
            then:
            else:
I found this code which seems to display various text values
power_monitor_plug_base.yaml and is based on Sonoff S31 esphome YAML for device cycle tracking (washer/dryer/dishwasher, etc) : r/homeassistant (reddit.com)> It’s too advanced for my level but may be a good template
@MatthewCMason I skimmed the post you linked but it appears to be customizing the outlet to somewhat guess what stage the device connected is at based on power draw. I actually implemented something similar in Node Red for my washer and dishwasher after observing graphs of the power draw over different cycles. In my opinion it is best to keep the outlets all the same (I have 20 of these) and then use the data they output in automations that figure out the device states and do whatever is needed, such as announcing when dishes / clothes are ready.
Starting to see size issues with OTA, any ideas on a work around? I already removed the web server.
“esphome s31 ESP does not have enough space to store OTA file”
I had MQTT enabled as well, I guess I have to remove it now to make space.
also, any solution to the impossible power factor?
@derekpurdy - Must be MQTT as my outlets seem to have “plenty” of memory left.
Linking .pioenvs/s31-outlet-20/firmware.elf
RAM:   [====      ]  43.1% (used 35336 bytes from 81920 bytes)
Flash: [=====     ]  47.7% (used 488501 bytes from 1023984 bytes)
Hmmm… don’t use a device such as a resistive light bulb with perfect PF :wink: - In all seriousness, I had forgotten about the issue as I don’t have any resistive loads on these 20+ outlets so the PF is always somewhat off 1.0. I had to plug in a 150W resistive light bulb I use for testing stuff like this to see it and I indeed have a wall of “Impossible Power Factor” in my logs.
I don’t know whether this is an ESPHome component bug or something I can even fix in the YAML but I do have an idea on, at least, how to hide the issue. I am thinking about making all sensors internal, using copy to expose them, and clamping the one for PF to between 0 and 1. I thin have to figure out whether this issue is just a side effect of a bad PF measurement… in other words are all the other values provided accurate but I may not have all the equipment needed to do this. Need to work on it…
