I have a problem with a Sonoff S55 (Tasmota) located in my garage ghost switching. I’m pretty sure this is due to the spotty internet connection in the garage.
It will stay switched on for a while and then turn off when it reconnects. I would like it to switch back on when it reconnects. I really need this to stay on as I use it for charging my car overnight.
I have tried the following commands:
SwitchRetain Off
ButtonRetain On
ButtonRetain Off
PowerOnState 3
PowerRetain On
and I’ve also deleted all previously retained messages by stopping the broker, deleting the DB file and restarting it.
Here is the MQTT config:
state_topic: tele/sonoffS55/STATE
availability_topic: tele/sonoffS55/LWT
payload_available: Online
payload_not_available: Offline
command_topic: cmnd/sonoffS55/POWER
value_template: '{{value_json.POWER}}'
payload_off: 'OFF'
payload_on: 'ON'
unique_id: AA6B4A_RL_1
device:
identifiers:
- AA6B4A
platform: mqtt
Here is a print out of the console from the moment I switched on the power and performed the commands above.
15:23:22 MQT: stat/sonoffS55/RESULT = {"POWER":"ON"}
15:23:22 MQT: stat/sonoffS55/POWER = ON (retained)
15:25:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:25:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"100","Signal (dBm)":"-50","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:25:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:25:16","Uptime":"3T19:25:30","UptimeSec":329130,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:30:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:30:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:30:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:30:16","Uptime":"3T19:30:30","UptimeSec":329430,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:33:07 CMD: SwitchRetain Off
15:33:07 MQT: stat/sonoffS55/SWITCH1T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH2T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH3T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH4T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH5T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH6T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH7T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/SWITCH8T = {"TRIG":"ON"}
15:33:07 MQT: stat/sonoffS55/RESULT = {"SwitchRetain":"OFF"}
15:33:22 CMD: ButtonRetain On
15:33:22 MQT: stat/sonoffS55/RESULT = {"ButtonRetain":"ON"}
15:33:30 CMD: ButtonRetain Off
15:33:30 MQT: stat/sonoffS55/BUTTON1T = {"TRIG":""}
15:33:30 MQT: stat/sonoffS55/BUTTON2T = {"TRIG":""}
15:33:30 MQT: stat/sonoffS55/BUTTON3T = {"TRIG":""}
15:33:30 MQT: stat/sonoffS55/BUTTON4T = {"TRIG":""}
15:33:30 MQT: stat/sonoffS55/RESULT = {"ButtonRetain":"OFF"}
15:33:41 CMD: PowerOnState 3
15:33:41 MQT: stat/sonoffS55/RESULT = {"PowerOnState":3}
15:33:49 CMD: PowerRetain On
15:33:49 MQT: stat/sonoffS55/RESULT = {"PowerRetain":"ON"}
15:35:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:35:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":20}
15:35:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:35:16","Uptime":"3T19:35:30","UptimeSec":329730,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:40:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:40:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:40:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:40:16","Uptime":"3T19:40:30","UptimeSec":330030,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:45:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:45:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:45:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:45:16","Uptime":"3T19:45:30","UptimeSec":330330,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:50:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:50:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:50:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:50:16","Uptime":"3T19:50:30","UptimeSec":330630,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
15:55:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T19:55:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
15:55:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T15:55:16","Uptime":"3T19:55:30","UptimeSec":330930,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:00:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:00:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:00:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:00:16","Uptime":"3T20:00:30","UptimeSec":331230,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:05:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:05:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:05:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:05:16","Uptime":"3T20:05:30","UptimeSec":331530,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:10:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:10:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:10:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:10:16","Uptime":"3T20:10:30","UptimeSec":331830,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:15:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:15:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:15:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:15:16","Uptime":"3T20:15:30","UptimeSec":332130,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:20:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:20:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:20:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:20:16","Uptime":"3T20:20:30","UptimeSec":332430,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:25:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:25:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:25:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:25:16","Uptime":"3T20:25:30","UptimeSec":332730,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:30:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:30:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"92","Signal (dBm)":"-54","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:30:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:30:16","Uptime":"3T20:30:30","UptimeSec":333030,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:35:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:35:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:35:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:35:16","Uptime":"3T20:35:30","UptimeSec":333330,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:40:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:40:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:40:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:40:16","Uptime":"3T20:40:30","UptimeSec":333630,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:45:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:45:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:45:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:45:16","Uptime":"3T20:45:30","UptimeSec":333930,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:50:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:50:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:50:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:50:16","Uptime":"3T20:50:30","UptimeSec":334230,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
16:55:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T20:55:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
16:55:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T16:55:16","Uptime":"3T20:55:30","UptimeSec":334530,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:00:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:00:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:00:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:00:16","Uptime":"3T21:00:30","UptimeSec":334830,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:05:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:05:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:05:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:05:16","Uptime":"3T21:05:30","UptimeSec":335130,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:10:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:10:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:10:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:10:16","Uptime":"3T21:10:30","UptimeSec":335430,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:15:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:15:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:15:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:15:16","Uptime":"3T21:15:30","UptimeSec":335730,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:20:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:20:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:20:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:20:16","Uptime":"3T21:20:30","UptimeSec":336030,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:25:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:25:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:25:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:25:16","Uptime":"3T21:25:30","UptimeSec":336330,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:30:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:30:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:30:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:30:16","Uptime":"3T21:30:30","UptimeSec":336630,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:35:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:35:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:35:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:35:16","Uptime":"3T21:35:30","UptimeSec":336930,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:40:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:40:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:40:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:40:16","Uptime":"3T21:40:30","UptimeSec":337230,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:45:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:45:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:45:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:45:16","Uptime":"3T21:45:30","UptimeSec":337530,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:50:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:50:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"98","Signal (dBm)":"-51","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:50:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:50:16","Uptime":"3T21:50:30","UptimeSec":337830,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
17:55:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T21:55:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"100","Signal (dBm)":"-49","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
17:55:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T17:55:16","Uptime":"3T21:55:30","UptimeSec":338130,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:04"}}
18:00:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T22:00:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"94","Signal (dBm)":"-53","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
18:00:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T18:00:16","Uptime":"3T22:00:30","UptimeSec":338430,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
18:05:09 MQT: tele/sonoffS55/HASS_STATE = {"Version":"8.5.1(tasmota)","BuildDateTime":"2020-10-02T10:09:47","Module or Template":"Sonoff S55","RestartReason":"Software/System restart","Uptime":"3T22:05:23","Hostname":"sonoffS55-2890","IPAddress":"192.168.1.143","RSSI":"96","Signal (dBm)":"-52","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:04","MqttCount":9,"LoadAvg":19}
18:05:16 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T18:05:16","Uptime":"3T22:05:30","UptimeSec":338730,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"ON","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
18:06:08 MQT: tele/sonoffS55/STATE = {"Time":"2020-10-11T18:06:08","Uptime":"3T22:06:22","UptimeSec":338782,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":9,"POWER":"OFF","Wifi":{"AP":1,"SSId":"SKY9316C_home","BSSId":"CC:32:E5:6A:91:9E","Channel":3,"RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
18:06:08 MQT: stat/sonoffS55/RESULT = {"POWER":"OFF"}
18:06:08 MQT: stat/sonoffS55/POWER = OFF (retained)
