I’m wondering if there is any Sonoff/Shelly alternative that uses zigbee instead of Wifi? The few ones I’ve found cost much more than Sonoff and Shelly. I really wonder why this is the case that there aren’t any good power switches available using zigbee which uses much less energy than Wifi.
IKEA Tradfri line has a smart switch which has similar features as with Sonoff / Shelly.
There are also other types on the market. Just Google “zigbee smart switch”.
I am currently in the process of transitioning from WiFi (esp8266 based) devices and sensors to zigbee alternatives. Once you reach a certain number of WiFi devices … the access point / WiFi router looses performance, and that’s my main reason to go for zigbee.
I have one of those, works perfectly. It’s a bit more expensive than a shelly (not quite double to get shipped to Australia) but still reasonably cheap.
For me Xiaomi (Aqara) 2-channel zigbee relay is not an alternative. I tried it, but it works bad with wall mounted momentary switches (need to push very fast to make it work properly, otherwise it turns off right away — Shelly works perfectly).
P.S. I tried aqara with Berker 5035 and Berker 503404.
