I have a problem with my Sonoff SNZB-01 switch.
I succesfully paired the switch to Zigbee2mqtt. It shows up in the list with the other devices.
Battery level, link quality and voltage shows up fine but when i press the button on the switch the output of action is ‘Empty string("")’
See image below
Even though now I also have this Empty string action, my automations (single & double click, long press too but with another one) do work.
So it seems this is not the reason that there is no response…
I had the same problem and fixed it by disabling the “Home Assistant legacy action sensors” in the Zigbee2MQTT settings.
After that all my automations automatically used the new event trigger.
If you use a automation blueprint it needs to be updated to use the new event trigger tough.
