Hello Everybody
I am taking my first steps into the HA platform.
Have installed it in a Windows VM and setup a few automations for a WIFI Yeelight bulb. They worked fine so I got a Nortek HUSBZB-1 USB dongle for Zwave and Zigbee protocols and a Sonoff SNZB-01 Zigbee switch to control this bulb.
Pairing and setup went well and after some research I discovered this type of switch works with events and no as entities so I setup a single press mode to toggle the status of the Yeelight. This works ok.
The problem I have is that the bulb is randomly turning off or on. This began to happen after the sonoff automation.
The automation is triggering and no one is pressing the button.
What have I tried:
Disable all automations for the bulb → the problem disappears
Enable only Sonoff switch toggle automation → problem comes back
Leave the switch right to the Zigbee antenna (because it is a couple of rooms from it) → problem continues
Versions:
Home Assistant 2021.9.3
OS Version 5.10.61
Does anybody have any idea what can be happening here?
Thanks!
