As an FYI, I just learned of a January 2021 update to the zigbee radio firmware for the Sonoff Zigbee Bridge. The update version is ncp-uart-sw_6.7.8.
see Tasmota/tools/fw_SonoffZigbeeBridge_ezsp at development · arendst/Tasmota · GitHub
This update fixes battery drain problems with IKEA Zigbee devices.
I wonder if it will fix the disconnection of the Sonoff SNZB-02 temperature sensors?
Some caveats of the update process are mentioned in this thread.
The key to the update is to change the Module type to 75.
All I did was change the Module type to (75), in the Tasmota Configuration page, and then was able to upload the new file without upload errors.
After the update, you then need to switch the Configuration back to the custom configuration (0) so it will function as a Zigbee bridge for ZHA, again.
