SONOFF SNZB-02DR2: Show remote sensor readings on the display
This blueprint sends temperature and humidity readings from up to two Home Assistant sensors to the SONOFF SNZB-02DR2 display using Zigbee2MQTT. The two independent remote slots appear as EXT1 and EXT2.
What’s included
- Independent temperature and humidity sources for EXT1 and EXT2.
- Validation for numeric values, supported ranges, and reading freshness.
- Fahrenheit and Kelvin conversion to °C.
- Per-reading fallback behavior.
- Configurable refresh interval and delay between MQTT writes.
- Optional restoration of the
onlinestate.
Requirements
- Home Assistant 2024.10 or later.
- MQTT integration enabled.
- Zigbee2MQTT exposing the
source_N_*properties. - SONOFF SNZB-02DR2 firmware 1.0.5 or later.
ZHA is not supported; this blueprint publishes directly to the Zigbee2MQTT MQTT topic.
Notes
The SNZB-02DR2 is battery-powered and may apply updated remote readings at its next check-in. Briefly pressing the button on its back can refresh the display sooner.
Blueprint and instructions: GitHub - ricfio/ha-blueprint-sonoff-snzb-02dr2-remote-sources: Home Assistant blueprint to show remote temperature/humidity (EXT1/EXT2) on the SONOFF SNZB-02DR2 display via Zigbee2MQTT. · GitHub
blueprint:
name: SONOFF SNZB-02DR2 (Zigbee2MQTT) - Remote Sources
description: |
Sends the temperature and/or humidity of up to two other sensors to the
**SONOFF SNZB-02DR2 (AirGuard TH)** so they are shown on its display.
**How it works**
The display has two independent remote slots: slot 1 is shown as **EXT1** and
slot 2 as **EXT2**, and they can be used together. For each slot you can pick a
temperature sensor, a humidity sensor, or both (each one is optional). Every value
is written in its own MQTT message (`source_N_temperature` / `source_N_humidity`)
with a short pause in between.
**Requirements**
- Zigbee2MQTT exposing `source_N_*` properties for the display
- MQTT integration enabled in Home Assistant
- SONOFF SNZB-02DR2 firmware 1.0.5 or later (first version with the two remote sources)
**Tested with**
- SONOFF SNZB-02DR2 firmware 1.0.5 (other firmware versions have not been tested)
**Notes**
- The display is a battery-powered sleepy device. According to the Zigbee2MQTT
documentation, new values are applied at its next check-in (the screen refreshes
from the remote sources every 30 minutes) or immediately after briefly pressing
the button on its back.
- A reading is sent only if it is numeric, uses a supported unit, is within range
(temperature -20 to 60 °C, humidity 0 to 100 %) and is not older than the configured
maximum age. Fahrenheit and Kelvin temperatures are converted to °C.
- Source changes are debounced and the latest values are evaluated after the quiet
period; periodic refresh and Home Assistant startup send without that delay.
- Invalid readings use the configured per-item fallback. When enabled, `online` is
published immediately before a valid value.
**Version:** 1.2.0
domain: automation
author: ricfio
source_url: https://github.com/ricfio/ha-blueprint-sonoff-snzb-02dr2-remote-sources/blob/main/blueprints/automation/sonoff-snzb-02dr2-remote-sources.yaml
homeassistant:
min_version: 2024.10.0
input:
display_section:
icon: mdi:monitor-dashboard
collapsed: false
input:
display_name:
name: Zigbee2MQTT name of the display
description: >-
The friendly_name of the SNZB-02DR2 in Zigbee2MQTT, exactly as it appears
there (case-sensitive).
selector:
text:
base_topic:
name: MQTT base topic
description: The Zigbee2MQTT base_topic. Keep the default unless you changed it.
default: zigbee2mqtt
selector:
text:
ext1_section:
name: EXT1 (remote slot 1)
icon: mdi:numeric-1-box-outline
collapsed: false
input:
temp_entity_1:
name: EXT1 temperature sensor
description: Leave empty if you do not want to send a temperature to EXT1.
default: ""
selector:
entity:
filter:
- domain: sensor
device_class: temperature
temp_fallback_1:
name: EXT1 temperature fallback
description: What to write if the EXT1 temperature source is not valid.
default: default
selector:
select:
mode: list
options:
- label: Use the default fallback
value: default
- label: Do nothing
value: none
- label: Mark offline
value: offline
- label: Unbind
value: unbound
hum_entity_1:
name: EXT1 humidity sensor
description: Leave empty if you do not want to send a humidity to EXT1.
default: ""
selector:
entity:
filter:
- domain: sensor
device_class: humidity
hum_fallback_1:
name: EXT1 humidity fallback
description: What to write if the EXT1 humidity source is not valid.
default: default
selector:
select:
mode: list
options:
value: default
- label: Do nothing
value: none
value: offline
- label: Unbind
value: unbound
ext2_section:
name: EXT2 (remote slot 2)
icon: mdi:numeric-2-box-outline
collapsed: false
input:
temp_entity_2:
name: EXT2 temperature sensor
description: Leave empty if you do not want to send a temperature to EXT2.
default: ""
selector:
entity:
filter:
- domain: sensor
temp_fallback_2:
name: EXT2 temperature fallback
description: What to write if the EXT2 temperature source is not valid.
default: default
selector:
select:
mode: list
options:
value: default
- label: Do nothing
value: none
value: offline
- label: Unbind
value: unbound
hum_entity_2:
name: EXT2 humidity sensor
description: Leave empty if you do not want to send a humidity to EXT2.
default: ""
selector:
entity:
filter:
- domain: sensor
hum_fallback_2:
name: EXT2 humidity fallback
description: What to write if the EXT2 humidity source is not valid.
default: default
selector:
select:
mode: list
options:
value: default
- label: Do nothing
value: none
value: offline
- label: Unbind
value: unbound
timing_section:
name: Update frequency
icon: mdi:timer-cog-outline
collapsed: true
input:
refresh_pattern:
description: >-
Resends the values at regular intervals, even without changes. Keeps the
display aligned and recovers from skipped updates.
default: "/30"
selector:
select:
mode: dropdown
options:
- label: Every 5 minutes
value: "/5"
- label: Every 10 minutes
value: "/10"
- label: Every 15 minutes
value: "/15"
- label: Every 20 minutes
value: "/20"
- label: Every 30 minutes
value: "/30"
throttle_seconds:
name: Source update debounce
description: >-
Waits for this many seconds of quiet after a source state change, then sends
the latest values. Further changes restart the wait, so the final useful
update is not discarded. Periodic refresh and startup are sent immediately.
default: 60
selector:
number:
min: 0
max: 240
step: 10
unit_of_measurement: s
mode: slider
safety_section:
name: Safety and fallback
icon: mdi:shield-check-outline
collapsed: true
input:
stale_minutes:
name: Maximum age of a source reading
description: >-
If a source sensor has not reported for longer than this, its value is
considered unreliable. Set to 0 to disable the check.
default: 120
selector:
number:
min: 0
max: 720
step: 10
unit_of_measurement: min
mode: box
fallback_mode:
name: Default fallback when a source reading is not valid
description: >-
Applies only to the affected item (for example EXT1 temperature).
"Mark offline" writes `offline` to its `source_N_*_state`; "Unbind" writes
`unbound`. How the display renders these states depends on the firmware.
Each item can override this in the EXT1 / EXT2 sections.
default: none
selector:
select:
mode: list
options:
- label: Do nothing
value: none
value: offline
- label: Unbind
value: unbound
restore_online:
name: Restore "online" when a source is valid again
description: >-
Writes `online` to the configured item's `source_N_*_state` immediately
before its valid value. State-only updates do not erase the measurement.
Adds one message for each valid configured item.
default: false
selector:
boolean:
advanced_section:
icon: mdi:cog-outline
collapsed: true
input:
set_status_using:
name: Enable remote sources (required)
description: >-
Sets remote_source_status to "using" before sending values,
as required by firmware 1.0.5 and later to enable remote sources.
default: true
selector:
boolean:
write_delay:
name: Pause between writes
description: >-
Seconds to wait between two consecutive messages sent to the display.
Avoids a write overriding the previous one.
default: 2
selector:
number:
min: 0
max: 10
step: 1
mode: slider
mode: restart
max_exceeded: silent
variables:
display_name: !input display_name
base_topic: !input base_topic
temp_entity_1: !input temp_entity_1
hum_entity_1: !input hum_entity_1
temp_entity_2: !input temp_entity_2
hum_entity_2: !input hum_entity_2
stale_minutes: !input stale_minutes
throttle_seconds: !input throttle_seconds
fallback_mode: !input fallback_mode
restore_online: !input restore_online
temp_fallback_1: !input temp_fallback_1
hum_fallback_1: !input hum_fallback_1
temp_fallback_2: !input temp_fallback_2
hum_fallback_2: !input hum_fallback_2
set_status_using: !input set_status_using
write_delay: !input write_delay
set_topic: "{{ base_topic | trim('/') }}/{{ display_name | trim('/') }}/set"
triggers:
- trigger: event
event_type: state_changed
event_data:
entity_id: !input temp_entity_1
- trigger: event
event_data:
entity_id: !input hum_entity_1
- trigger: event
event_data:
entity_id: !input temp_entity_2
- trigger: event
event_data:
entity_id: !input hum_entity_2
- trigger: time_pattern
minutes: !input refresh_pattern
- trigger: homeassistant
event: start
conditions:
- alias: React to state or unit changes, but ignore unrelated attribute changes
condition: template
value_template: >-
{{ trigger.id != 'source_changed'
or trigger.event.data.old_state is none
or trigger.event.data.new_state is none
or trigger.event.data.new_state.state != trigger.event.data.old_state.state
or trigger.event.data.new_state.attributes.unit_of_measurement
!= trigger.event.data.old_state.attributes.unit_of_measurement }}
actions:
- alias: Coalesce source changes and use the latest state
if:
- condition: template
value_template: "{{ trigger.id == 'source_changed' and throttle_seconds | int(0) > 0 }}"
then:
- delay:
seconds: "{{ throttle_seconds | int(0) }}"
- alias: Optionally set remote_source_status to "using"
if:
value_template: "{{ set_status_using }}"
then:
- action: mqtt.publish
topic: "{{ set_topic }}"
qos: 1
retain: false
payload: '{"remote_source_status": "using"}'
- delay:
seconds: "{{ write_delay }}"
- alias: Process each remote slot
repeat:
for_each:
- slot: 1
temp: "{{ temp_entity_1 }}"
hum: "{{ hum_entity_1 }}"
t_fb: "{{ temp_fallback_1 }}"
h_fb: "{{ hum_fallback_1 }}"
- slot: 2
temp: "{{ temp_entity_2 }}"
hum: "{{ hum_entity_2 }}"
t_fb: "{{ temp_fallback_2 }}"
h_fb: "{{ hum_fallback_2 }}"
sequence:
- variables:
slot: "{{ repeat.item.slot }}"
t_ent: "{{ repeat.item.temp }}"
h_ent: "{{ repeat.item.hum }}"
# Effective fallback of each item: per-item override or the default
t_fallback: "{{ fallback_mode if repeat.item.t_fb == 'default' else repeat.item.t_fb }}"
h_fallback: "{{ fallback_mode if repeat.item.h_fb == 'default' else repeat.item.h_fb }}"
# Keep the full precision for range validation; round only for transmission.
t_c_raw: >-
{%- if t_ent | string | length > 0 and is_number(states(t_ent)) -%}
{%- set v = states(t_ent) | float -%}
{%- set u = state_attr(t_ent, 'unit_of_measurement') | string | trim -%}
{%- if u in ['°C', '℃'] -%}{{ v }}
{%- elif u in ['°F', '℉'] -%}{{ (v - 32) * 5 / 9 }}
{%- elif u == 'K' -%}{{ v - 273.15 }}
{%- endif -%}
{%- endif -%}
t_c: "{{ t_c_raw | float | round(1) if t_c_raw != '' else '' }}"
t_unit: "{{ state_attr(t_ent, 'unit_of_measurement') | string | trim }}"
h_unit: "{{ state_attr(h_ent, 'unit_of_measurement') | string | trim }}"
# Humidity is accepted only when its unit is percent.
h_c: >-
{%- if h_ent | string | length > 0 and is_number(states(h_ent)) and h_unit == '%' -%}
{{ [states(h_ent) | float | round(1), 99.9] | min }}
{%- endif -%}
# Age of last_reported (not last_changed), preserving sub-minute precision.
t_age: >-
{%- if t_ent | string | length == 0 or states[t_ent] is none -%}
999999
{%- else -%}
{{ (now() - states[t_ent].last_reported).total_seconds() / 60 }}
{%- endif -%}
h_age: >-
{%- if h_ent | string | length == 0 or states[h_ent] is none -%}
999999
{%- else -%}
{{ (now() - states[h_ent].last_reported).total_seconds() / 60 }}
{%- endif -%}
# skip = not configured, ok = valid, invalid = configured but not usable
t_status: >-
{%- if t_ent | string | length == 0 -%}skip
{%- elif t_c_raw != '' and t_unit in ['°C', '℃', '°F', '℉', 'K'] and -20 <= t_c_raw | float <= 60
and (stale_minutes | int(0) == 0 or t_age | float <= stale_minutes | int(0)) -%}ok
{%- else -%}invalid{%- endif -%}
h_status: >-
{%- if h_ent | string | length == 0 -%}skip
{%- elif h_c != '' and h_unit == '%' and 0 <= states(h_ent) | float <= 100
and (stale_minutes | int(0) == 0 or h_age | float <= stale_minutes | int(0)) -%}ok
- alias: Temperature
choose:
- conditions:
value_template: "{{ t_status == 'ok' }}"
sequence:
- if:
value_template: "{{ restore_online }}"
then:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_temperature_state": "online"} | tojson }}'
- delay:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_temperature": t_c | float} | tojson }}'
- delay:
- conditions:
value_template: "{{ t_status == 'invalid' and t_fallback != 'none' }}"
sequence:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_temperature_state": t_fallback} | tojson }}'
- delay:
- alias: Humidity
choose:
- conditions:
value_template: "{{ h_status == 'ok' }}"
sequence:
- if:
then:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_humidity_state": "online"} | tojson }}'
- delay:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_humidity": h_c | float} | tojson }}'
- delay:
- conditions:
value_template: "{{ h_status == 'invalid' and h_fallback != 'none' }}"
sequence:
qos: 1
retain: false
payload: '{{ {"source_" ~ slot ~ "_humidity_state": h_fallback} | tojson }}'
- delay:
