I just purchased an additional SNZB-03 motion sensor, as the first one was working great.
When trying to pair it directly via an MQTT dongle however, it’s appearing as a SNZB-02 (temp sensor?) and then failing to configure.
Any advice ?
I have updated the home assistant and MQTT plug ins recently - is there maybe a bug in the new release?
Is there any way I can manually add the configuration for the new sensor directly into a yaml file ?
thanks
drcref
November 6, 2020, 2:32pm
2
I have the same problem with a pair of SNZB-03 sensors I received today from Sonoff Tech Store on AliExpress. I’m using a CC2531 dongle. They get paired as SNZB-02 in zigbee2mqtt:
Zigbee2MQTT:info 2020-11-06 14:29:37: Device '0x00124b002247b69b' joined
Zigbee2MQTT:info 2020-11-06 14:29:37: Starting interview of '0x00124b002247b69b'
Zigbee2MQTT:info 2020-11-06 14:29:37: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x00124b002247b69b"},"type":"device_connected"}'
Zigbee2MQTT:info 2020-11-06 14:29:37: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x00124b002247b69b"},"type":"pairing"}'
Zigbee2MQTT:info 2020-11-06 14:29:37: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x00124b002247b69b"},"type":"device_announced"}'
Zigbee2MQTT:info 2020-11-06 14:29:52: Successfully interviewed '0x00124b002247b69b', device has successfully been paired
Zigbee2MQTT:info 2020-11-06 14:29:52: Device '0x00124b002247b69b' is supported, identified as: SONOFF Temperature and humidity sensor (SNZB-02)
Zigbee2MQTT:info 2020-11-06 14:29:52: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Temperature and humidity sensor","friendly_name":"0x00124b002247b69b","model":"SNZB-02","supported":true,"vendor":"SONOFF"},"type":"pairing"}'
I’ve managed to clone my working SNB-03 entry in the /share/zigbee2mqtt/database.db file to hack in the new entry. Motion is working by not battery level or signal quality.
I wonder if there is some firmware difference in some of the units ?
drcref
November 6, 2020, 4:35pm
4
Good to hear! Can you please share the working entry? Does the battery and link level work on your older SNZB-03? It does seem like the firmware has changed on the new sensors we have, weird that it gets identified as an SNZB-02 though.
Here you go:
{"id":2,"type":"EndDevice","ieeeAddr":"0x00124b0021354f99","nwkAddr":4595,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"MS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0
,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"MS01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20191107"}},"ssIasZone":{"attributes":{"iasCi
eAddr":"0x00124b0014da264f","zoneState":1}},"genPowerCfg":{"attributes":{"batteryVoltage":32,"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da264f","endpointID":1}],"meta"
:{}}},"appVersion":3,"hwVersion":1,"dateCode":"20191107","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1604671385507}
Yes on the first sensor, everything works fine. It’s got an older address (21354f99) vs the new sensor in the (22xxxxxx) range.
drcref
November 6, 2020, 7:28pm
7
Thanks. I’ve managed to get the sensors to work by overwriting their entries with yours above (replacing the addresses with those from the existing entries). I removed the “genPowerCfg” bit from the entry and now I also get battery and link level:
{"id":10,"type":"EndDevice","ieeeAddr":"0x00124b002247b69b","nwkAddr":32549,"manufId":0,"manufName":"eWeLink","powerSource":"Battery","modelId":"MS01","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1],"outClusterList":[3],"clusters":{"genBasic":{"attributes":{"modelId":"MS01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20191107"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0008ca0718","zoneState":1}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0008ca0718","endpointID":1}],"meta":{}}},"appVersion":3,"hwVersion":1,"dateCode":"20191107","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1604689798504}
benek984
(Benek984)
November 25, 2020, 3:44pm
8
I was able to add my sensor using your advise. Shows connected, battery level is also displayed but doesn’t report moments. It constantly shows clear/
Any ideas?
Reset
(Reset)
December 3, 2020, 3:12pm
9
Since got mine one. can’t sleep well haha…official Update please. There’re other solution to fix this issue by switch to the dev branch (Visit https://www.zigbee2mqtt.io/how_tos/how-to-switch-to-dev-branch.html )
hollosipeti
(Péter Hollósi)
December 4, 2020, 7:25pm
10
Hi!
Today i updated Zigbee2mqtt to version: 1.16.2.2.
And this problem is solved!
francisp
(Francis)
December 5, 2020, 7:30am
11
Yes, since 1.16.2 I can see the battery too.
