I am using a Sonoff SNZB-03 motion sensor with the Sonoff ZBBridge (flashed with Tasmota). I was able to set everything up without issue using the Zigbee Home Automation and the sensor was working for a while before I started having problems with it.
Last week I noticed that the sensor had been showing in Home Assistant as unavailable for a few days. I had to set it to pairing mode and reconnect with the bridge and then it started working again for a few days. This morning I noticed it was unavailable again.
Right now this is the only Zigbee device Iām running but I was planning to add a few more over the next month or two. Iām wondering if I am doing something wrong or if thereās just an issue with the Sonoff sensor. Any suggestions on how to troubleshoot further?
I had some of those and I sent them all back. They are very poor. Loads of false triggers etc.
I bought Philips hue ones and have not had a single problem since I installed them over 6 months ago.
I concur about the lower quality but had little issues so far. The HUE ones are indeed another level also on price butā¦ they come with light/temp sensorā¦worth the extra EUR/USD
Thanks. I was thinking of trying Aqara since those seem to be reasonably priced and have better reviews than Sonoff. Just wanted to make sure that there wasnāt some user error at play before I blamed the device.
sonoff is cheap-ish so yes you can start to blame the device although (repeating) I am quite OK with it.
No hassle often means paying for it but it is also no guaranteeā¦
Myself, I am just trying things out: hue is really stable (twice the price), sonoff/innr ok, the tuya branded stuff both zigbee/wifi provide me more headaches.
So my advice is: use quality stuff for key sensors and there is no reaosn to try out cheapoās for less critical ones
I am also using ZHA and have the same motion sensor and the same issue. My SNZB-03 is in a room which is not used much and seems to go to sleep and then reports as āunavailableā. However, if someone goes into the room the red light flashes to indicate motion has been detected and after that it becomes available.
I have just noticed that there is a setting in the ZHA integration which says āconsider battery powered devices unavailable after (seconds)ā and the default is 21600 (6 hours). I have just reset this to 36 hours. I shall let you know if this solves the problem. I am guessing that when a device is marked as āunavailableā by ZHA it no longer gets polled?
UPDATE: Turns out I was wrong about the timeout - increasing it to 36 hours made no difference. I then swapped it with another SNZB-03 motion sensor and the problem went away. @vingerha is correct - these are poor quality devices and unreliable.
