trying to upload the below code
esphome:
platform: ESP8266
board: nodemcuv2
board_flash_mode: dout
wifi:
ssid: "xxx"
password: "xxx"
manual_ip:
static_ip: 192.168.1.1
gateway: 192.168.1.2
subnet: 255.255.255.0
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
web_server:
port: 80
ota:
uart:
rx_pin: RX
baud_rate: 4800
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Sonoff SV green LED"
output: sonoff_sv_green_led
- platform: wifi_signal
name: "Sonoff SV WiFi Signal"
update_interval: 60s
- platform: uptime
name: "Sonoff SV Uptime"
# Enable time component to reset energy at midnight
time:
- platform: homeassistant
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff SV Button"
on_press:
- switch.toggle: sonoff_sv_fakebutton
- platform: status
name: "Sonoff SV status"
switch:
optimistic: true
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
- platform: restart
name: "Sonoff SV restart"
text_sensor:
- platform: version
name: "Sonoff SV ESPHome Version"
