Sonoff SwitchMan R5 Scene Controller Blueprint
Hi everyone, I hope this is helpful to someone.
I created a bluprint to trigger automations based on the sonoff R5 scene controller.
The blueprint requires that your sonoff R5 entity exists in home assistant through the HACS sonoff LAN integration, thanks to AlexxIT on github for that. The integration needs to be configured as auto (R5 is not supported in local only mode, at least to date)
The R5 also requires to be paired through the eWelink app to any of M5 smart switch, S40/S40 Lite smartplug, eWeLink-Remote gateway as a sort of bridge. (Select device in ewelink, go to it’s configs and look for subdevices option). It also requires that the “bridge” device is in a fair range and up.
Once your R5 is linked to your “Bridge” device, it should show in the HACS sonoff integration, and you can start using the blueprint.
If the above button does not work, you can manually add the blueprint.
Download the yaml file sonoff_switchman_r5.yaml and put it in your home assistant “config/blueprints/automation” folder (you may also create a folder under it and put the yaml there).
Or, copy the blow code and create a yaml file in said folder.
blueprint:
  name: Sonoff R5 button actions
  description: Actions for a specific Sonoff R5 button (Requires the R5 to be added using the "Sonoff LAN" HACS integration, in auto mode, will not work with local only. https://github.com/AlexxIT/SonoffLAN)
  domain: automation
  author: Erick Rodriguez
  input:
    sonoff_r5_entity:
      description: Select the R5 entity.
      selector:
        entity:
          domain: sensor
          integration: sonoff
    r5_button_name:
      description: Select the R5 button that will trigger the automation.
      selector:
        select:
          mode: dropdown
          options:
            - label: Button 1
              value: button_1
            - label: Button 2
              value: button_2
            - label: Button 3
              value: button_3
            - label: Button 4
              value: button_4
            - label: Button 5
              value: button_5
            - label: Button 6
              value: button_6
    press_action:
      description: Action to perform when single pressing the selected button.
      default: []
      selector:
        action: {}
    double_press_action:
      name: Double Press Action
      description: Action to perform when double pressing the selected button.
      default: []
      selector:
        action: {}
    hold_action:
      description: Action to perform when hold pressing the selected button (this will trigger the action multiple times until the button is released).
      default: []
      selector:
        action: {}
    automation_mode:
      description: Select the R5 button automation mode (https://www.home-assistant.io/docs/automation/modes/).
      default: queued
      selector:
        select:
          mode: list
          options:
            - queued
            - single
            - restart
            - parallel
variables:
  sonoff_r5_entity: !input 'sonoff_r5_entity'
  r5_button_name: !input r5_button_name
  single_trigger_state: "{{ r5_button_name }}_single"
  double_trigger_state: "{{ r5_button_name }}_double"
  hold_trigger_state: "{{ r5_button_name }}_hold"
  event_state: "{{ trigger.event.data.new_state.state }}"
  press_action: !input 'press_action'
  double_press_action: !input 'double_press_action'
  hold_action: !input 'hold_action'
- platform: event
  event_type: state_changed
  event_data:
    entity_id: !input 'sonoff_r5_entity'
- choose:
  - conditions:
    - condition: template
      value_template: "{{ single_trigger_state == event_state }}"
    sequence: !input 'press_action'
  - conditions:
      value_template: "{{ double_trigger_state == event_state }}"
    sequence: !input 'double_press_action'
  - conditions:
      value_template: "{{ hold_trigger_state == event_state }}"
    sequence: !input 'hold_action'
mode: !input automation_mode
Hopefully it works for you.
Update:
I also created a blueprint that works similarly but it would create a single automation to configure all buttons actions instead of having one automation per button of the R5.
Pro: This blueprint permits defining a single automation to control all actions of all the buttons in the R5
Con: You can only use a single automation mode for all actions (queued, parallel, single, restart)
Salve, è da poco che utilizzo HA e forse mi sfugge qualcosa. Ho copiato il file nella mia configurazione ma ora come devo fare per utilizzarlo?
Would anyone know if there is an equivalent Blueprint for the Sonoff M5?
Al my R5’s stopped working. I think it was since HA 2025.9
They show on the log in eWelink but not in HA
Solved: I needed to re-login with password for ewelink. I was in DIY mode
