Hi, got a sonoff t1-1 (r2)
i have flashed it to esphome, however the touchbutton is acting wierd, when i press the touch it recognizes it and send ON, immidiatly after it sends OFF
[00:36:29][D][binary_sensor:037]: ‘Living Room Roof Touchpad’: Sending state ON
[00:36:29][D][binary_sensor:037]: ‘Living Room Roof Touchpad’: Sending state OFF
my yaml looks like this:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "*************"
password: "**********"
# Enable logging
logger:
# Enable Home Assistant API
api:
password: '********'
ota:
password: '*********'
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Living Room Roof Touchpad"
switch:
- platform: gpio
name: "Living Room Roof"
pin: GPIO12
output:
- platform: esp8266_pwm
pin: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Living Room Blue LED"
output: blue_led
Am i doing something wrong or is it anything else?
note:
It was working a few hours ago when i had installed it, then i pushed update to change the name of the binary sensor and the switch…
nickrout
(Nick Rout)
May 26, 2019, 11:49pm
2
Please post your code correctly, see How to help us help you - or How to ask a good question
Perhaps you need some debouncing?
@nickrout Thanks! I will try that tonight
I tried up to 1000ms delay for off but it didnt do anything at all…
Any other tips?
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_off: 1000ms
I also tried this:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 50ms
max_length: 350ms
then:
- switch.turn_on: relay_1
on_double_click:
min_length: 50ms
max_length: 350ms
then:
- switch.turn_off: relay_1
Single click will turn the lights on, double click turns it off but also on…
Ok for future reference, this solved my problem:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay_1
switch:
- platform: gpio
pin: GPIO12
Hello @Pelle_Kallstrom
I am having the same issue of ghost switching. Glad to know your solved the problem. Just to confirm what I understood is that I should not use output and light functions and just use the binary_sensor and switch functions.
