I’m not able to toggle both switches of my Sonoff T1 2CH with latest tasmota flashed on.
Device is added as cover into HASS but unfortunately I cannot control. Target is to control my shutters with this switch. I have found lot of configuration examples but I wasn’t able to adapt them.
Here is my config:
cover:
- platform: mqtt
state_topic: "stat/rollo_WohnzFenster/POWER"
#value_template: '{{ value_json["POWER"] }}' # tried also with this command, result is same
command_topic: "cmnd/rollo_WohnzFenster/power"
availability_topic: "tele/rollo_WohnzFenster/LWT"
qos: 1
payload_open: "power1 ON" #just for testing purpose , I'll ned later on to send 2 commands, but firstly I need to make this work with this setup
payload_close: "power2 ON"
payload_stop: "power1 OFF;power2 OFF"
payload_available: "Online"
payload_not_available: "Offline"
state_open: "ON"
state_closed: "OFF"
retain: true
#optimistic: true
Here is the console output from my sonoff tasmota when I try to control / toggle via HASS:
I don’t have a tasmota, but from other posts I think the command matches the status message, so I would change the command topic to this and see what happens. If not, you will have to wait for someone with a tasmota
Sure, makes sense but I’ll need both switches to make my shutter working. Also I want to avoid to display two devices.
Nevertheless, let me try with Power1, at least to toggle the first Switch. Additionally I could work with Backlog functionality and add both commands into one payload. I don’t know what is the best solution here.
Tried also with Power1, unfortunately it doesn’t work. I can only toggle when I’m using as command topic following parameter:
here you ran in the same trap i ran the last 8 hours
we got 1 definitive problem…
“we are both german” and we like a german config masks
so we compiled our tasmota with german lang include and thats the problem.
in detail:
when using language file:
el-GR.h
en-GB.h
es-AR.h
hu-HU.h
it-IT.h
nl-NL.h
all is fine because definition inside the lang file :
in our case: de-DE.h
contents is: #define D_OFFLINE “offline” #define D_ONLINE “online”
so in the german lang file its low_case
in all other language files as example: pl-PL.h #define D_OFFLINE “Nieaktywny” #define D_ONLINE “Aktywny”
i think the documentation should be made better or the language files
should be overhauled to set them all to “Offline” and “Online” because this is a technical value and not relevant for user interface.
Fazit: set the values in HASS from “Online” to “online” and “Offline” to “offline”
Thanks for your reply! I am using all my interfaces in Germany in English, therefore I assume the issue is not related to my language settings
Today I went back to tasmota 5.14 but issue still persists.
