Sonoff T1 US/AU config
I have been trying to setup my Sonoff Light Switch(2 channel) to Hassio.
I have been able to get it to turn on the light be immediately after i turn it on in hassio the button switches to off but the light stays on. I cannot get it to turn off via hassio only on.
my code is below.
# Enables the frontend
frontend:
mqtt:
  broker: core-mosquitto
  # Enables configuration UI
config:
panel_iframe:
  configurator:
    title: Configurator
    icon: mdi:wrench
    url: http://192.168.1.139:3218
switch:
    platform: mqtt
    name: "Sonoff Switch 01"
    command_topic: "cmnd/sonoff/power"
    state_topic: "stat/sonoff/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    state_on: "ON"
    state_off: "OFF"
    retain: true
If it helps this is my config, you will need to change IP address and username / password to what ever you are using.
configuration.yaml
mqtt:
  broker: 192.168.x.x
  port: 1883
  keepalive: 60
  username: user
  password: userpass
light:
  - platform: mqtt
    state_topic: "stat/sonoffMB/POWER"
    command_topic: "cmnd/sonoffMB/POWER"
    availability_topic: "tele/sonoffMB/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: false
If you have a light switched on before HA starts it wont know if it’s on or not so add the following to
automations.yaml
#Check Power Status on startup for Sonoff Devices
- alias: "Power state on HA start-up"
    platform: homeassistant
    event: start
    - service: mqtt.publish
        topic: "cmnd/sonoffs/power1"
        payload: ""
        topic: "cmnd/sonoffs/power2"
        payload: ""
        topic: "cmnd/sonoffs/Power3"
        payload: ""
        topic: "cmnd/sonoffs/power4"
        payload: ""
        topic: "cmnd/sonoffs/power5"
        payload: ""
Hope it helps.
This happens because ha does not receive the state_topic: message with a payload matching payload_on: after the command has been sent.
Use a mqtt client to display the messages being sent. and match your
state_topic: and payload to that being sent. I tend to use mosquitto_sub for this see mqtt testing page but I have heard people using an app called mqtt.fx with some success.
Didn’t a recent firmware update make the topic power1 and power2???
Hi All,
Many thanks, with the help of everyone i have managed to get it to work.
Thanks guys you are very helpful and very quick!!!
Code below that is working.
light:
    platform: mqtt
    state_topic: "stat/sonoff/POWER1"
    command_topic: "cmnd/sonoff/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
sorry another question!
To add the second switch do I do it like below?
light:
    platform: mqtt
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
light2:
    platform: mqtt
    state_topic: "stat/sonoff/POWER2"
    command_topic: "cmnd/sonoff/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
Yeah as per next post… I was trying to edit. iPad is not cooperating!
Is it a double wall switch or two seperate ones? (Edit Miss read, you have said it’s a dual)
If it’s a double light switch then yes. Otherwise you need to change the sonoff part ie:
cmnd/sonoffLM/POWER1
cmnd/sonoffLS/POWER1
cmnd/sonoffBob/POWER1
The bit between cmnd and POWER is the device name.
This might help more
  - platform: mqtt
    state_topic: "stat/sonoffLM/POWER"
    command_topic: "cmnd/sonoffLM/POWER"
    availability_topic: "tele/sonoffLM/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: mqtt
    state_topic: "stat/sonoffLS/POWER"
    command_topic: "cmnd/sonoffLS/POWER"
    availability_topic: "tele/sonoffLS/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
You will change the Topic on each sonoff
Thanks guys… All working.
Thanks too.
any direction on how to set this up in Node Red?
Cheers
OK but this is WITH tasmota right?
