Sonoff Tasmota MQTT problem
I check this forum and read but not find solution. If i turn on switch in hass , after some sec it turned off. This is Sonoff SV with 2 relays and ds18b20. Temperature working ok.
From console : 08:53:27 MQT: sonoff/tele/STATE = {“Time”:“2019-09-03T08:53:27”,“Uptime”:“0T10:05:15”,“Heap”:14,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER1”:“OFF”,“POWER2”:“OFF”,…
and for temperature : 09:08:28 MQT: sonoff/tele/SENSOR = {“Time”:“2019-09-03T09:08:28”,“DS18B20”:{“Temperature”:21.1},“TempUnit”:“C”}
Hass.io MQTT server working.
configuration.yaml
https://pastebin.com/qy312gEg
He is one of my MQTT switches
  - platform: mqtt
    state_topic: "stat/Tv-Lava/POWER"
    command_topic: "cmnd/Tv-Lava/POWER"
    payload_on: "ON"
    payload_off: "OFF"
    optimistic: false
    qos: 0
the console
now something with temperature
its consloe
  - platform: mqtt
    name: "Garage Temperature"
    state_topic: "tele/GarageDoor/SENSOR"
    value_template: "{{value_json['DHT11'].Temperature }}"
    unit_of_measurement: "°C"
  - platform: mqtt
    name: "Garage Humidity"
    value_template: "{{value_json['DHT11'].Humidity }}"
    unit_of_measurement: "%"
hope this helps
see clear as mud
Mqtt working perfect. If i turn switch in lovelace hass.io on, sonoff turns on. After some seconds switch in lovelace turned off but in sonoff swich stays on.
Sorry my english.
switch:
  • platform: mqtt
    state_topic: “sonoff/tele/RESULT”
    command_topic: “cmnd/sonoff/POWER1”
    payload_on: “ON”
    payload_off: “OFF”
    state_on: “ON”
    state_off: “OFF”
    optimistic: false
    qos: 0
  • platform: mqtt
    name: “Kurkla kastmine”
    command_topic: “cmnd/sonoff/POWER2”
    payload_on: “ON”
    payload_off: “OFF”
    state_on: “ON”
    state_off: “OFF”
    optimistic: false
    qos: 0
Should be
state_topic: “stat/sonoff/POWER1”
This is not possible but working. :slight_smile: Many thanks. Some beers from me.
Question 2. How to turn off POWER2 after 120 seconds if i turn it on. This switch for greenhouse watering valve. Watering cucumbers. Some time i forget turn it off.
Entity : switch.kurkla_kastmine
The easiest way to do this is to set a pulsetime in the Tasmota console.
You also create an automation in home assistant to turn off the switch after a certain time.
OK.
I check how to do this.
Try typing ‘pulsetime2 220’ in the Tasmota console window
I need this delay 120sec for POWER2 only.
I don’t have a dual switch but according to the documentation, pulsetime2 should be for power2
You need to type the following in the console for 120 seconds
Pulsetime2 220
This may be useful if you want to try to do this in home assistant.
I try this and test. Thanks. This working.
Then second question. :slight_smile:
First relay in greenhouse open door. Today this working from Fibaro. Open door by time. This is not good choice. For temp i connect ds18b20 to Sonoff SV… Relay turn on and door open. If relay turn off door close. I need open door by temeperature. If in greenhouse temperature +24, relay turn on and door open. If temperature +22 relay turned off and door closed. Something like thermostat.
You can configure a generic thermostat in home assistant. It’s fairly simple. You just need to configure a switch and temp sensor in the config.
climate:
  • platform: generic_thermostat
    cooler: switch.kurkla_uks # relay what open door. Not need switch off when open. If switch this relay off then door closes.
    target_sensor: sensor.kurkla_temp
    target_temp: 23
I need : if temp >23 : sensor.kurkla_temp
switch on : switch.kurkla_uks
and
if temp <22
switch off : switch.kurkla_uks
There is an option to set the generic thermostat as a cooler, used for air conditioning, etc. It should then work the way you want.
please format your code make it easyer to read
target_temp: 23
see that look beater a
now here is mine Office Temperature Climate control
  - platform: generic_thermostat
    name: "Office Temperature"
    heater: switch.office_fan
    target_sensor: sensor.office_temperature
    min_temp: 15
    max_temp: 30
    ac_mode: true
    target_temp: 24
    cold_tolerance: 1.5
    hot_tolerance: 1.5
    initial_hvac_mode: "off"
    away_temp: 16
the tick is with the
    cold_tolerance: 1.5
    hot_tolerance: 1.5
and the
Thank you. I try. How this working. Outdoor temp is only +13 today. Greenhouse is empty. Next year again.
    target_temp: 23
This opens door but not close. I set target temp 13 degrees. At the moment outdoor temp is +10.
