Sonoff Tasmota MQTT
Sorry if im posting in a wrong forum topic.
Im new to HASS trying to convert from Domoticz. I have a couple of Sonoff switches with Tasmota. (They work in the addon TasmoAdmin) im trying to get them to work in HASS… Either via MQTT or something that just work…
This is my configuration.yaml on mqtt
Mqtt
mqtt:
broker: m23.cloudmqtt.com
port: xxxxx
username: username(its correct)
password: password(its correct)
switch:
  • platform: mqtt
    command_topic: “cmnd/Test/OFF”
    state_topic: “stat//Test/off”
    payload_on: “ON”
    payload_off: “OFF”
    qos: 0
    retain: True
  • platform: mqtt
    command_topic: “cmnd/sonoff1/OFF”
    state_topic: “stat//sonoff1/off”
    payload_on: “ON”
    payload_off: “OFF”
    qos: 0
    retain: True
This is how my Sonoff mqtt config looks like for one of my switches:
Host
m23.cloudmqtt.com
Port
Xxxxx(Yep correct port)
Client
Testmqtt
User
Username
Password
Password
Topic
Sonoff1
Full Topic
(%prefix%/%topic%/)
See that big blue box at the top of the page? It’ll be easier for people to help you if you post having inserted your extracts in a readable fashion
Hello. I have noticed something to try:
The Full Topic of the Sonoff switch config indicates that your state and command topics should be: prefix/topic/. You have prefix/topic/OFF. Try removing OFF in both the state and command topics.
One thing that I do when troubleshooting MQTT is to make sure MQTT works without Home Assistant. I use the Chrome Extension MQTT BOX to help isolate the issue to MQTT or HA.
Also make sure that each MQTT client device has a unique ClientID. I have made that mistake before.
Hope this helps.
