Sonoff Tasmota not working - new user
Hi new to Home Assistant but successfully got it running on a Pi (0.96.2). I have 2 Sonoff S20 sockets that work using the built in web interface following loading the Tasmota firmware (6.6.0).
I can’t get HA to add the discovered Sonoff component using Belkin Wemo emulation with “MQTT enable unticked”.
  1. Do I need to use MQTT with Sonoff?
  2. Yaml file. I have added the Configurator add-on and select “OPEN WEB UI” and this is all there is:
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
Any help would be much appreciated. I have had a bit of a trawl but any direction for intro reading would be great too. Many thanks
The error I get is Wemo devices in the discovered section. Select CONFIGURE
“Aborted No Wemo devices found on the network”
But can still connect to them using their fixed ip.
John
Did you ever work this out? I’ve had SAME issue for three days strait!!
