Sonoff Tasmota - relay state wiring
I’m new to home automation and based in the UK.
I’m looking at wiring the lighting in a property using the star method. and want to integrate home automation. I was looking at using the sonoff 4 ch pro r2. I want to use the physical light switches in addition to the sonoff. I was looking at this for an arrangement.
The problem however occurs that if you alternate between the switches and sonoff, the state of the light is incorrect.
Now the question!!! :slight_smile:
is it possible with tasmota / home assistant to have the reported state (ie light on/off) to be based on if there is power at the common on the relay? or do i need to rethink i my idea?
Thanks in advance
