Sonoff Tasmota S2X oscillating?
yesterday i’ve integrated my Sonoff S2X to MQTT and HA. Today i recognized that the switches always turns on and off again (i’ve no automation on this) - even the switch itself is not turned on or off by myself.
The S2X is also emulating a Belkin WeMo and HTTP API as well MQTT is enabled, could this be the reason?
And in the console theres just written:
11:24:25.416 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:24:25","Uptime":"0T14:05:10","UptimeSec":50710,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:29:25.411 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:29:25","Uptime":"0T14:10:10","UptimeSec":51010,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:34:25.413 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:34:25","Uptime":"0T14:15:10","UptimeSec":51310,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:39:25.420 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:39:25","Uptime":"0T14:20:10","UptimeSec":51610,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:44:25.369 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:44:25","Uptime":"0T14:25:10","UptimeSec":51910,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:49:25.414 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:49:25","Uptime":"0T14:30:10","UptimeSec":52210,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:54:25.403 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:54:25","Uptime":"0T14:35:10","UptimeSec":52510,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
11:59:25.384 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T11:59:25","Uptime":"0T14:40:10","UptimeSec":52810,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:04:25.384 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T12:04:25","Uptime":"0T14:45:10","UptimeSec":53110,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:09:25.369 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T12:09:25","Uptime":"0T14:50:10","UptimeSec":53410,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
12:14:25.381 MQT: lightstele/tasmota/STATE = {"Time":"2022-07-07T12:14:25","Uptime":"0T14:55:10","UptimeSec":53710,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"FRITZ!Box 7490","BSSId":"","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
Someone already had this kind of szenario?
Thanks in advance!
did you ever found out what was causing the issue? My Sonoff device started the same thing 3 days ago, always when the Input is HIGH. No clue whats going on -_-
