I have some Sonoff Switches that I have loaded the Tasmoto Firmware onto. It works great as far as HA toggling it on and off along with knowing its state when the button or web ui toggles it on and off. However I have a problem when the Sonoff gets power cycled like getting unplugged and plugged back in while it is toggled on. When it gets unplugged obviously the sonoff switches off but HA holds the toggle as being on as expected since it wasnt notified that it shut off. However when the Sonoff gets plugged back in it turns on as expected since the retain settings are set but it seems as though as soon as HA sees that it is back up HA shuts it off.
I have been searching through other threads but all i can really find is people having issue with HA having the proper state. I do not believe that is the case in this problem as it seems as though HA is actually shutting the switch off once it sees that it is back online.
Here is the Configuration in HA (Note this is running on a RPI3 with HASSIO. The MQTT Broker is the one included with HASSIO)
- platform: mqtt
command_topic: “cmnd/Phils-Desk-Lamp/power”
state_topic: “stat/Phils-Desk-Lamp/POWER”
qos: 1
payload_on: “ON”
payload_off: “OFF”
retain: true
Here is the Tasmoto user_config.h settings
// – Localization --------------------------------
//#define MY_LANGUAGE en-GB // Enabled by Default
//#define MY_LANGUAGE nl-NL
// – Project -------------------------------------
#define PROJECT “sonoff” // PROJECT is used as the default topic delimiter and OTA file name
// As an IDE restriction it needs to be the same as the main .ino file
#define CFG_HOLDER 0x20161209 // [Reset 1] Change this value to load following default configuration parameters
#define SAVE_DATA 1 // [SaveData] Save changed parameters to Flash (0 = disable, 1 - 3600 seconds)
#define SAVE_STATE 1 // [SetOption0] Save changed power state to Flash (0 = disable, 1 = enable)
// – Wifi ----------------------------------------
#define WIFI_IP_ADDRESS “0.0.0.0” // [IpAddress1] Set to 0.0.0.0 for using DHCP or IP address
#define WIFI_GATEWAY “192.168.2.254” // {IpAddress2] If not using DHCP set Gateway IP address
#define WIFI_SUBNETMASK “255.255.255.0” // [IpAddress3] If not using DHCP set Network mask
#define WIFI_DNS “192.168.2.27” // [IpAddress4] If not using DHCP set DNS IP address (might be equal to WIFI_GATEWAY)
#define STA_SSID1 “Automation” // [Ssid1] Wifi SSID
#define STA_PASS1 “” // [Password1] Wifi password
#define STA_SSID2 “” // [Ssid2] Optional alternate AP Wifi SSID
#define STA_PASS2 “” // [Password2] Optional alternate AP Wifi password
#define WIFI_CONFIG_TOOL WIFI_WPSCONFIG // [WifiConfig] Default tool if wifi fails to connect
// (WIFI_RESTART, WIFI_SMARTCONFIG, WIFI_MANAGER, WIFI_WPSCONFIG, WIFI_RETRY, WIFI_WAIT)
// – Syslog --------------------------------------
#define SYS_LOG_HOST “domus1” // [LogHost] (Linux) syslog host
#define SYS_LOG_PORT 514 // [LogPort] default syslog UDP port
#define SYS_LOG_LEVEL LOG_LEVEL_NONE // [SysLog]
#define SERIAL_LOG_LEVEL LOG_LEVEL_INFO // [SerialLog]
#define WEB_LOG_LEVEL LOG_LEVEL_INFO // [WebLog]
// – Ota -----------------------------------------
#define OTA_URL “http://domus1:80/api/arduino/” PROJECT “.ino.bin” // [OtaUrl]
// – MQTT ----------------------------------------
#define MQTT_USE 1 // [SetOption3] Select default MQTT use (0 = Off, 1 = On)
// !!! TLS uses a LOT OF MEMORY (20k) so be careful to enable other options at the same time !!!
//#define USE_MQTT_TLS // EXPERIMENTAL Use TLS for MQTT connection (+53k code, +20k mem) - Disable by //
// Needs Fingerprint, TLS Port, UserId and Password
#ifdef USE_MQTT_TLS
#define MQTT_HOST “m20.cloudmqtt.com” // [MqttHost]
#define MQTT_FINGERPRINT “A5 02 FF 13 99 9F 8B 39 8E F1 83 4F 11 23 65 0B 32 36 FC 07” // [MqttFingerprint]
#define MQTT_PORT 20123 // [MqttPort] MQTT TLS port
#define MQTT_USER “cloudmqttuser” // [MqttUser] Mandatory user
#define MQTT_PASS “cloudmqttpassword” // [MqttPassword] Mandatory password
#else
#define MQTT_HOST “10.152.7.65” // [MqttHost]
#define MQTT_PORT 1883 // [MqttPort] MQTT port (10123 on CloudMQTT)
#define MQTT_USER “MQTT” // [MqttUser] Optional user
#define MQTT_PASS “” // [MqttPassword] Optional password
#endif
#define MQTT_BUTTON_RETAIN 1 // [ButtonRetain] Button may send retain flag (0 = off, 1 = on)
#define MQTT_POWER_RETAIN 1 // [PowerRetain] Power status message may send retain flag (0 = off, 1 = on)
#define MQTT_SWITCH_RETAIN 1 // [SwitchRetain] Switch may send retain flag (0 = off, 1 = on)
#define MQTT_STATUS_OFF “OFF” // [StateText1] Command or Status result when turned off (needs to be a string like “0” or “Off”)
#define MQTT_STATUS_ON “ON” // [StateText2] Command or Status result when turned on (needs to be a string like “1” or “On”)
#define MQTT_CMND_TOGGLE “TOGGLE” // [StateText3] Command to send when toggling (needs to be a string like “2” or “Toggle”)
#define MQTT_CMND_HOLD “HOLD” // [StateText4] Command to send when button is kept down for over KEY_HOLD_TIME * 0.1 seconds (needs to be a string like “HOLD”)
// – MQTT topics ---------------------------------
//#define MQTT_FULLTOPIC “tasmota/bedroom/%topic%/%prefix%/” // Up to max 80 characers
#define MQTT_FULLTOPIC “%prefix%/%topic%/” // [FullTopic] Subscribe and Publish full topic name - Legacy topic
// %prefix% token options
#define SUB_PREFIX “cmnd” // [Prefix1] Sonoff devices subscribe to %prefix%/%topic% being SUB_PREFIX/MQTT_TOPIC and SUB_PREFIX/MQTT_GRPTOPIC
#define PUB_PREFIX “stat” // [Prefix2] Sonoff devices publish to %prefix%/%topic% being PUB_PREFIX/MQTT_TOPIC
#define PUB_PREFIX2 “tele” // [Prefix3] Sonoff devices publish telemetry data to %prefix%/%topic% being PUB_PREFIX2/MQTT_TOPIC/UPTIME, POWER and TIME
// May be named the same as PUB_PREFIX
// %topic% token options (also ButtonTopic and SwitchTopic)
#define MQTT_TOPIC PROJECT // [Topic] (unique) MQTT device topic
#define MQTT_GRPTOPIC “sonoffs” // [GroupTopic] MQTT Group topic
#define MQTT_CLIENT_ID “DVES_%06X” // [MqttClient] Also fall back topic using Chip Id = last 6 characters of MAC address
// – MQTT - Telemetry ----------------------------
#define TELE_PERIOD 300 // [TelePeriod] Telemetry (0 = disable, 10 - 3600 seconds)
// – MQTT - Domoticz -----------------------------
//#define USE_DOMOTICZ // Enable Domoticz (+7k code, +0.3k mem) - Disable by //
#define DOMOTICZ_IN_TOPIC “domoticz/in” // Domoticz Input Topic
#define DOMOTICZ_OUT_TOPIC “domoticz/out” // Domoticz Output Topic
#define DOMOTICZ_UPDATE_TIMER 0 // [DomoticzUpdateTimer] Send relay status (0 = disable, 1 - 3600 seconds) (Optional)
// – HTTP ----------------------------------------
#define USE_WEBSERVER // Enable web server and wifi manager (+62k code, +8k mem) - Disable by //
#define WEB_SERVER 2 // [WebServer] Web server (0 = Off, 1 = Start as User, 2 = Start as Admin)
#define WEB_PORT 80 // Web server Port for User and Admin mode
#define WEB_USERNAME “admin” // Web server Admin mode user name
#define WEB_PASSWORD “” // [WebPassword] Web server Admin mode Password for WEB_USERNAME (empty string = Disable)
#define FRIENDLY_NAME “Sonoff” // [FriendlyName] Friendlyname up to 32 characters used by webpages and Alexa
#define USE_EMULATION // Enable Belkin WeMo and Hue Bridge emulation for Alexa (+11k code, +2k mem)
#define EMULATION EMUL_NONE // [Emulation] Select Belkin WeMo (single relay/light) or Hue Bridge emulation (multi relay/light) (EMUL_NONE, EMUL_WEMO or EMUL_HUE)
// – mDNS ----------------------------------------
#define USE_DISCOVERY // Enable mDNS for the following services (+8k code, +0.3k mem) - Disable by //
#define WEBSERVER_ADVERTISE // Provide access to webserver by name .local/
#define MQTT_HOST_DISCOVERY // Find MQTT host server (overrides MQTT_HOST if found)
// – Time - Up to three NTP servers in your region
#define NTP_SERVER1 “pool.ntp.org” // [NtpServer1] Select first NTP server by name or IP address (129.250.35.250)
#define NTP_SERVER2 “nl.pool.ntp.org” // [NtpServer2] Select second NTP server by name or IP address (5.39.184.5)
#define NTP_SERVER3 “0.nl.pool.ntp.org” // [NtpServer3] Select third NTP server by name or IP address (93.94.224.67)
// – Time - Start Daylight Saving Time and timezone offset from UTC in minutes
#define TIME_DST Last, Sun, Mar, 2, +120 // Last sunday in march at 02:00 +120 minutes
// – Time - Start Standard Time and timezone offset from UTC in minutes
#define TIME_STD Last, Sun, Oct, 3, +60 // Last sunday in october 02:00 +60 minutes
// – Application ---------------------------------
#define APP_TIMEZONE 1 // [Timezone] +1 hour (Amsterdam) (-12 … 12 = hours from UTC, 99 = use TIME_DST/TIME_STD)
#define APP_LEDSTATE LED_POWER // [LedState] Function of led (LED_OFF, LED_POWER, LED_MQTTSUB, LED_POWER_MQTTSUB, LED_MQTTPUB, LED_POWER_MQTTPUB, LED_MQTT, LED_POWER_MQTT)
#define APP_PULSETIME 0 // [PulseTime] Time in 0.1 Sec to turn off power for relay 1 (0 = disabled)
#define APP_POWERON_STATE 2 // [PowerOnState] Power On Relay state (0 = Off, 1 = On, 2 = Toggle Saved state, 3 = Saved state)
#define APP_BLINKTIME 10 // [BlinkTime] Time in 0.1 Sec to blink/toggle power for relay 1
#define APP_BLINKCOUNT 10 // [BlinkCount] Number of blinks (0 = 32000)
#define APP_SLEEP 0 // [Sleep] Sleep time to lower energy consumption (0 = Off, 1 - 250 mSec)
#define KEY_HOLD_TIME 40 // [SetOption32] Number of 0.1 seconds to hold Button or external Pushbutton before sending HOLD message
#define SWITCH_MODE TOGGLE // [SwitchMode] TOGGLE, FOLLOW, FOLLOW_INV, PUSHBUTTON, PUSHBUTTON_INV, PUSHBUTTONHOLD or PUSHBUTTONHOLD_INV (the wall switch state)
#define WS2812_LEDS 30 // [Pixels] Number of WS2812 LEDs to start with
#define TEMP_CONVERSION 0 // [SetOption8] Return temperature in (0 = Celsius or 1 = Fahrenheit)
#define TEMP_RESOLUTION 1 // [TempRes] Maximum number of decimals (0 - 3) showing sensor Temperature
#define HUMIDITY_RESOLUTION 1 // [HumRes] Maximum number of decimals (0 - 3) showing sensor Humidity
#define PRESSURE_RESOLUTION 1 // [PressRes] Maximum number of decimals (0 - 3) showing sensor Pressure
#define ENERGY_RESOLUTION 3 // [EnergyRes] Maximum number of decimals (0 - 5) showing energy usage in kWh
// – Sensor code selection -----------------------
#define USE_ADC_VCC // Display Vcc in Power status. Disable for use as Analog input on selected devices
//#define USE_DS18x20 // Optional using OneWire library for multiple DS18B20 and/or DS18S20 (+2k code)
//#define USE_I2C // I2C using library wire (+10k code, 0.2k mem) - Disable by //
#define USE_BH1750 // Add I2C code for BH1750 sensor
#define USE_BMP // Add I2C code for BMP/BME280 sensor
#define USE_HTU // Add I2C code for HTU21/SI7013/SI7020/SI7021 sensor
#define USE_SHT // Add I2C emulating code for SHT1X sensor
//#define USE_IR_REMOTE // Send IR remote commands using library IRremoteESP8266 and ArduinoJson (+3k code, 0.3k mem)
// #define USE_IR_HVAC // Support for HVAC system using IR (+2k code)
//#define USE_WS2812 // WS2812 Led string using library NeoPixelBus (+5k code, +1k mem) - Disable by //
#define USE_WS2812_CTYPE 1 // WS2812 Color type (0 - RGB, 1 - GRB)
// #define USE_WS2812_DMA // DMA supports only GPIO03 (= Serial RXD) (+1k mem)
// When USE_WS2812_DMA is enabled expect Exceptions on Pow
- Compile a minimal version if upgrade memory gets tight ONLY TO BE USED FOR UPGRADE STEP 1!
- To be used as step 1 during upgrade.
- Step 2 is re-compile with option BE_MINIMAL commented out.
- !!! Needed for next release of Arduino/ESP8266 (+22k code, +2k mem) !!!
//#define BE_MINIMAL // Minimal version if upgrade memory gets tight (-45k code, -2k mem)
- No user configurable items below
#if defined(USE_MQTT_TLS) && defined(USE_WEBSERVER)
#error “Select either USE_MQTT_TLS or USE_WEBSERVER as there is just not enough memory to play with”
#endif
#if (ARDUINO < 10610)
#error “This software is supported with Arduino IDE starting from 1.6.10 and ESP8266 Release 2.3.0”
#endif
