I am busy moving all of my ESP-based devices to ESPhome. The one remaining device I have is a Sonoff TH10 with DS18B20 temperature sensor. Does nayone have a sample connfig to control the switch, button and temperature sensor for use in HA?
Thanks!
Thanks!
Hi, were you able to get it working? Thinking about doing the same
No - currently still on Tasmota as I couldn’t figure it out. Switch and button are pretty straightforward, but I couldn’t find any info on the temp sensor.
Ok will keep you posted
Solved it by following this explanation: https://esphome.io/components/sensor/dallas.html
Just add first this config:
dallas:
- pin: GPIO14
Then compile & download the binary and upload it through the tasmota web interface.
In the output you will then see the address of the sensor appearing and then you can edit the config and add this:
- platform: dallas
address: 0x2A03189779311128
name: "Zwembad Temperatuur"
That’s it works as a charm
Good luck!
Great - mny thanks for posting! Will give it a try.
Do you mind sharing your whole config (button, switch etc.)?
Of course not:
substitutions:
device_name: zwembad_temperatuur
friendly_name: "Zwembad Temperatuur"
dallas_address: "0xDC03219779B4F228"
sonoff_type: "TH10"
esphome:
platform: ESP8266
board: esp8285
arduino_version: 2.4.2
wifi:
ssid: !secret wifi_ssid
ap:
ssid: ${friendly_name} FB
password: !secret esphome_admin_password
captive_portal:
logger:
api:
web_server:
port: 80
ota:
dallas:
- pin: GPIO14
- platform: wifi_signal
name: ${friendly_name} ${sonoff_type} WiFi Signal
update_interval: 60s
- platform: dallas
address: ${dallas_address}
- platform: uptime
name: ${friendly_name} ${sonoff_type} Uptime
update_interval: 120s
binary_sensor:
- platform: status
name: ${friendly_name} ${sonoff_type} Status
switch:
- platform: restart
name: ${friendly_name} ${sonoff_type} Restart
- platform: gpio
pin: GPIO12
#restore_mode: ALWAYS_OFF
text_sensor:
- platform: wifi_info
ip_address:
name: ${friendly_name} ${sonoff_type} IP
ssid:
name: ${friendly_name} ${sonoff_type} SSID
bssid:
name: ${friendly_name} ${sonoff_type} BSSID
