Sonoff TH16 + Tasmota - Temperature not showing?
So I installed a sonoff TH16. Flashed with Tasmota and connected a DS18B20 thermometer probe.
Probe is selected on GPIO14 (DS18x20). Connected to HA with the Tasmota integration (first time i tried it, quite nice) and it works fine as a relay.
From what I understand it doesn’t show the temp on the Sonoff web interface which is weird as the other 2 temp probes do. Their way no matter what I do, I can’t get the temperature into HA. I’ve looked at various form posts, some older and new and I just don’t get anything when I create the sensor.
If someone has this working which I am sure many do, can you please share your YAML with me so I can compare?
Mine shows up in the web interface, and in the console. It’s setup as a Sonoff TH (4) and on GPIO14. It gets pulled into HA via the Tasmota integration(so no yaml). Does the probe work on other devices? Could be a faulty connection or similar.
18:45:51.722 MQT: tele/tasmota_SN_TH16/SENSOR = {"Time":"2022-02-02T18:45:51","DS18B20":{"Id":"3C01F0964A78","Temperature":21.3},"TempUnit":"C"}
OK well if it’s meant to show up in the web interface then I guess that’s my issue as it isn’t for me when the DS18B20 is selected. I’ll just reflash it a few more times and home that it comes right. Thanks
Pretty sure it needs a restart after connecting the probe too. See if you can try the probe on something else. Good luck
