brafster
(Brafster)
1
I have a Sonoff TH16 running tasmota with a SI7021 sensor. The temperature is displaying on the frontend, but not humidity.
Sensor entry:
- platform: mqtt
name: “Garage Temperature”
state_topic: “tele/garagepowertemp/SENSOR”
qos: 1
value_template: “{{ value_json.SI7021.Temperature }}”
unit_of_measurement : “°C”
- platform: mqtt
name: “Garage Humidity”
qos: 1
value_template: “{{ value_json.SO7021.Humidity }}”
Module state:
09:55:44 MQT: tele/garagepowertemp/SENSOR = {“Time”:“2019-03-13T09:55:44”,“SI7021”:{“Temperature”:19.3,“Humidity”:73.9},“TempUnit”:“C”}
Dielee
(Linus Dietz)
2
Please use the code block for code, this makes it easier to read the code.
Above is missing an ‘I’. In your config is an ‘O’.
Try this:
- platform: mqtt
qos: 1
value_template: “{{ value_json.SI7021.Humidity }}”
brafster
(Brafster)
3
Oh my goodness! Happens when you stare at a problem too long. Thanks so much. Working now.
Tried using the code block button but it didn’t seem to work (this was my first post)…
dmo147
(dmo147)
4
I followed your config for temperature but my display looks like this instead of just showing 21.9°C.
- platform: mqtt
state_topic: "tele/sonoff_th1/SENSOR"
qos: 1
value_template: “{{ value_json.DS18B20.Temperature }}”
dmo147
(dmo147)
5
Sorted. Changing double-quote to single-quote corrected it.
