today I discovered that one of mine Sonoff TRVZB, integrated trough Zigbee2MQTT, had changed closing steps value.
Its value was 37 so the valve didn’t work as it could not open/close the radiator.
All other valves have this value between 376 and 443.
I tried to remove from Z2M and pair again, no solution.
I tried to hardware reset it via sonoff instructions, made a hardware calibration, and then pair again and the value changed from 37 to 44, still too low.
Then I removed and block listed it, Harwdare reset, re calibrate it and then removed from block list, and paired again.
This way the value of closing steps went to 398 and the TRV is working fine.
What could be the problem?
Is there any way I could debug this behaviour for next possible evenience?
