Yes agreed. Another example: only left/right swiping, no swipe up/down. I only have a 1 gang version but it seems like the only control that applies to each separate gang is the single touch. So you can’t swipe on gang 1 or gang 2 for example. The M5 switch allows tap, double tap or even long press per gang/relay.
I really hope more functionality can be exposed by a firmware update and this is not some hardware limitation. Apart from these issues, a really nice switch.
@Zoldex on the EU/UK version a blue LED on the board lights up. Are you applying ground to the boot solder point on the board also? Recommend you follow this video by @smarthomeyourself.de (you can enable captions for translation if needed) or check the illustrations here.
