SONOFF TX Ultimate switch
Is the SONOFF TX Ultimate switch compatible with home assistant?
If so do I need to flash it similar to the Switchman M5 switches?
Interested in this topic too as I just got myself a TX Ultimate but need it to be in Home Assistant before I can actually use it. I would prefer the flashing ESPHome option so I can uncouple the relays from the buttons.
I got this working with ESPHome by using the code from github below
To flash it with ESPHome see this image
USB –> TX 5
3V –> R15
RXD –> TXD
TXD –> RXD
GND –> GND
BOOT –> GND
Not got the sound working yet though.
That’s great news!! I’ve just bought mine.
Question, What can you control with that code? The relays obviously but what about the LEDs and vibrations etc?? Thanks in advance…
So I uncoupled 2 of the 3 buttons
Button 1 turns on hallway light home assistant
Button 2 turns on toilet light in home assistant
Button 3 turns on relay for dehumidifier.
I also control the lights that light up around each light that is powered on
You can control all 28 led’s individually or together as shown in the code below.
The one thing it doesn’t control is that annoying button press on and off sound
Here is the code I used:
Dont forget to download the 2 additional files and have them in your ESPHome directory
touch_panel.hpp
touch_panel.cpp
# Built using:
# https://gist.github.com/wolph/42024a983e4dfb0bc1dcbe6882979d21
substitutions:
  # Brightness and night light brightness
  brightness_on: 80%
  brightness_nightlight: 0%
esphome:
  platform: ESP32
  board: esp32dev
  on_boot:
    priority: -100.0
    then:
      - button.press: light_relays
  includes:
    - touch_panel.hpp
    - touch_panel.cpp
# Enable logging
logger:
#  level: DEBUG
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Tx-Hallway"
# Enable Bluetooth Proxy
esp32_ble_tracker:
    scan_parameters:
      interval: 1100ms
      window: 1100ms
      active: true
bluetooth_proxy:
  active: true
# Home Assistant Light State change
text_sensor:
  # turn on TX light when halway light in HA is turned on
  - platform: homeassistant
    entity_id: light.hallway_light
    on_value:
  # turn on TX light when Toilet light in HA is turned on
    entity_id: light.toilet_light
    on_value:
  # Bedtime routine here reserved for future
    entity_id: input_boolean.gone_to_bed
uart:
  tx_pin: 19
  rx_pin: 22
  baud_rate: 115200
button:
    on_press:
      - if:
          condition:
              text_sensor.state:
                state: 'on'
          then:
            - light.turn_on:
                brightness: ${brightness_on}
                red: 0%
                green: 100%
                blue: 0%
                transition_length: 500ms
          else:
            - light.turn_on:
                brightness: ${brightness_nightlight}
                red: 0%
                green: 0%
                blue: 0%
                transition_length: 2s
      - if:
          condition:
              text_sensor.state:
                state: 'on'
          then:
            - light.turn_on:
                red: 0%
                green: 100%
                blue: 0%
          else:
            - light.turn_on:
                red: 0%
                green: 0%
                blue: 0%
      - if:
          condition:
            switch.is_on: relay3
          then:
            - light.turn_on:
                red: 0%
                green: 100%
                blue: 0%
          else:
            - light.turn_on:
                red: 0%
                green: 0%
                blue: 0%
binary_sensor:
  - platform: custom
    lambda: |-
        auto touch_panel = new touch_panel::TouchPanel(id(uart_bus));
        App.register_component(touch_panel);
        return {
          touch_panel->left,
          touch_panel->middle,
          touch_panel->right,
          touch_panel->two_finger,
          touch_panel->dragged_ltr,
          touch_panel->dragged_rtl,
    binary_sensors:
      - id: button_left
        on_press: # Turn on Hallway light in HA
          - homeassistant.service:
              service: "light.toggle"
                entity_id: "light.hallway_light"
          - switch.turn_on: haptics
          - delay: 2s
      - id: button_middle
        on_press: # Turn on Toilet light in HA
                entity_id: "light.toilet_light"
          - delay: 2s
      - id: button_right
        on_press: # Turn on relay for dehumidifier
          - switch.toggle: relay3
          - delay: 2sec
      - id: button_two_finger
      - id: button_dragged_ltr
        name: "Dragged Left to Right"
      - id: button_dragged_rtl
        name: "Dragged Right to Left"
# Switch Relays
switch:
  - platform: gpio
    pin: GPIO18
    restore_mode: ALWAYS_ON # Smart light bulb so must be always on
    on_turn_on:
    on_turn_off:
  - platform: gpio
    pin: GPIO17
    restore_mode: ALWAYS_OFF # Nothing connected to this
    on_turn_on:
    on_turn_off:
  - platform: gpio
    pin: GPIO27
    restore_mode: ALWAYS_OFF # Dehumidifier default off
    on_turn_on:
    on_turn_off:
  - platform: gpio
    pin: GPIO23
    on_turn_on:
    on_turn_off:
  - platform: gpio
    name: "sound amplifier power"
    pin: GPIO26
  - platform: gpio
    name: "touch panel power"
    pin:
      number: GPIO5
      inverted: true
    restore_mode: RESTORE_DEFAULT_ON
  - platform: gpio
    pin: GPIO21
    on_turn_on:
      - delay: 400ms
      - switch.turn_off: haptics
# Light
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812
    pin: GPIO13
    num_leds: 1
    internal: true
    type: GRB
    variant: WS2812
    # pin: GPIO20
    pin: GPIO33
    num_leds: 28
    name: "Ambience Nightlight"
    effects: # Found additional effects but not tested them all
      - addressable_rainbow:
          speed: 50
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
      - pulse:
          # transition_length: 1s      # defaults to 1s
          update_interval: 2s
      - addressable_scan:
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 100ms
          scan_width: 3
      - addressable_twinkle:
          name: Twinkle Effect With Custom Values
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_random_twinkle:
          name: Random Twinkle Effect With Custom Values
          twinkle_probability: 20%
          progress_interval: 32ms
      - addressable_fireworks:
          name: Fireworks Effect With Custom Values
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
      - addressable_flicker:
          name: Flicker Effect With Custom Values
          update_interval: 16ms
          intensity: 5%
  - platform: partition
    name: "light left both"
    segments:
      - id: rgb_light
        to: 21
    name: "light middle both"
    segments:
      - id: rgb_light
        to: 24
      - id: rgb_light
        to: 10
    name: "light right both"
    segments:
      - id: rgb_light
        to: 7
      - id: rgb_light
        to: 27
    segments:
      - id: rgb_light
        to: 5
    segments:
      - id: rgb_light
        to: 19
I have just put this together to hopefully he
Perhaps this is an option too
substitutions:
  friendly_name: "SHYS TX Ultimate"
  relay_count: "2"
packages:
  smarthomeyourself.tx-ultimate: github://SmartHome-yourself/sonoff-tx-ultimate-for-esphome/tx_ultimate.yaml@main
esphome:
  name_add_mac_suffix: false
api:
ota:
wifi:
  ap:
    ssid: ${friendly_name} AP
    password: "top_secret"
tx_ultimate_touch:
  uart: my_uart
  on_press:
    - lambda: >
        ESP_LOGD("tx_ultimate_touch.on_press", "My Event: Position: %d / State: %d", touch.x, touch.state);
  on_release:
    - light.turn_off: leds
The on_ actions are optional to extend main functions. But for minimal use, you only need the code above the tx_ultimate component.
Good morning, yesterday I was trying to flash my TX with Chris firmware, but after some more reading your firmware seams a lot easier to configure after in HA for a noob like me :wink:
I finally got it working, thanks for your share.
The vibration options, can I turn it off on HA or do I need to re-flash it again?
Thanks, and have a nice Sunday! :wink:
Re-flashing with ESPtools in HA is really easy.
May I ask you if its possible to use the switch as a blessing tracker? I have some ESPrensense and if I could use the switch to do the both things would be awesome.
Thanks.
Once you have flashed it with ESPHome and you have ESPHome on your home assistant you can just comment out all the lines with replace all
  • switch.turn_on: haptics
    #- switch.turn_on: haptics
Then Install & chose wireless
That will do an over the air update so not having to connect the cables again
ESPrensense only allows specific IO inputs like Temp, Motion. So until ESPHome or someone releases there own Prensense detection then no.
Hello!
I would like to buy more TX Ultimate switches. I have small children and they will be delighted. At the same time, I want to buy some smart G10 bulbs from Shelly with integrated Wifi, RGB and dimmer. I would like to create scenarios with the TX Ultimate switch, for example to be able to dim the brightness of all bulbs or only certain bulbs and to be able to change the colors. Is it possible if I integrate in HA? Will I have to rewrite the firmware with ESP Home? The manufacturer does not specify exactly whether these scenarios can be realized through the Ewelink application. Anyway, probably only with Sonoff bulbs, but they don’t have the G10 bulb type.Thank you!
The way I do this is just to program the lights in HA. Import the switch states from the Sonoff and use those to controll any light you want. I am not a fan of coding everything in an ESPHome device. Just sensors and actuators, and leaving the control to HA
Hello everyone.
Out of curiosity, after flashing esphome, is there any way to reflash the original fw?
Thank you.
Yes, you can flash your backed up firmware over serial. You did back it up before flashing esphome, right?
My knowledge on the subject is very limited, basically following videos, and was not aware of that step of the process, and was hoping that if needed the binaries could be found somewhere in the internet.
I still have 5 wall switches in the box, so i’ll search how to get a backup from one of them.
Thank you for making me aware of this.
My 2 switches arrived today so will also be looking figure out how to back up their stock firmware before I start trying to get ESPHome onto them :slight_smile:
My switches are the “US” version so are a portrait rectangle and not a square.
I flashed it using this link below but all the LEDs don’t correlate to the switch being pressed etc…
Maybe someone has got the “US” version working?
Has anyone got this working nicely on the US rectangle version?
Having had a fairly extensive play with the TX Ultimate combined with your code and some variations by others and my own I have come to the conclusion that the switch is very clunky due to, I assume, sonoff onboard code.
Examples:
  • Swipe Left and Right have to be done at exactly the right speed and pressure level to register.
  • My attempts to implement the recognition of a double click have been too hard to get user friendly - timing and touch pressure sensitivity.
  • There are a range of light effects which seem embedded - eg following a successful swipe left or right, the top lights put on a colourful show that is not under the control of esphome code.
  • A long press duration is not adjustable.
Am I missing something or do others agree ?
