Hi there!
I installed ESPHome firmware in my sonoff tx-ultimate switch and tonight I faced a bug when vibro started working instantly and switch couldn’t work properly (nothing happend when I touched it).
Sound of vibro was like when I first time flashed this firmware into module.
What could it be? I thought that it couldn’t connect to HomeAssistant (I powered off it for the night) and it sarted to rollback the firmware to last version? I don’t know if it can do such operation, could it?
If it happens one more time, I will try to record a video. Anyway, I need know what it could be and how to fix it, because waking up every night doesen’t sound good))
Waiting for somebodies answer!
PS: for this sonoff device I use custom component (GitHub - SmartHome-yourself/sonoff-tx-ultimate-for-esphome: ESPHome Custom Component for Sonoff TX Ultimate) but it seems, the problem is in ESPHome firmware in common.
PPS:
This is how it looks like: Быстрый обмен файлами
Here is my yaml file:
substitutions:
nname: LivingRoom_Switch
friendly_name: LivingRoom Switch
relay_count: "1"
toggle_relay_1_on_touch: "true"
vibra_time: 45ms
button_on_time: 100ms
button_brightness: "0.7"
button_color: "{0,0,100}"
nightlight: "on"
nightlight_brightness: "0.9"
nightlight_color: "{100,65,7}"
latitude: "50.123456°"
longitude: "5.654321°"
touch_brightness: "1"
touch_color: "{0,100,100}"
touch_effect: ""
long_press_brightness: "1"
long_press_color: "{100,0,0}"
long_press_effect: ""
multi_touch_brightness: "1"
multi_touch_color: "{0,0,0}"
multi_touch_effect: ""
swipe_left_brightness: "1"
swipe_left_color: "{0,100,0}"
swipe_left_effect: ""
swipe_right_brightness: "1"
swipe_right_color: "{100,0,70}"
swipe_right_effect: ""
relay_1_pin: GPIO18
vibra_motor_pin: GPIO21
pa_power_pin: GPIO26
led_pin: GPIO13
status_led_pin: GPIO33
uart_tx_pin: GPIO19
uart_rx_pin: GPIO22
audio_lrclk_pin: GPIO4
audio_bclk_pin: GPIO2
audio_sdata_pin: GPIO15
touchpanel_power_pin: GPIO5
web_server:
port: 80
esphome:
friendly_name: ultimate-switch
project:
version: "1.0"
on_boot:
priority: -100
then:
- binary_sensor.template.publish:
state: OFF
state: OFF
state: OFF
state: OFF
state: OFF
- script.execute: refresh_led_default
- script.execute: refresh_nightlight
esp32:
board: esp32dev
framework:
type: arduino
logger:
level: DEBUG
logs:
binary_sensor: INFO
light: INFO
script: INFO
switch: INFO
tx_ultimate_touch: INFO
uart_debug: INFO
# Enable Home Assistant API
api:
reboot_timeout: 0s
encryption:
key: "baQ2xdKUNa************+0Fn93OkzgfUPd7wBBukC9KfY="
ota:
password: "********c599d2169ac84ad8d415*****"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Ultimate-Switch Fallback Hotspot"
password: "11111111"
improv_serial:
captive_portal:
external_components:
# - source: /config/esphome/my_components
- source:
type: git
url: https://github.com/SmartHome-yourself/sonoff-tx-ultimate-for-esphome
ref: main
components: [tx_ultimate_touch]
globals:
- id: nightlight_color
type: int [3]
restore_value: no
initial_value: ${nightlight_color}
- id: button_color
type: int [3]
restore_value: no
initial_value: ${button_color}
- id: long_press_color
type: int [3]
restore_value: no
initial_value: ${long_press_color}
- id: multi_touch_color
type: int [3]
restore_value: no
initial_value: ${multi_touch_color}
- id: swipe_left_color
type: int [3]
restore_value: no
initial_value: ${swipe_left_color}
- id: swipe_right_color
type: int [3]
restore_value: no
initial_value: ${swipe_right_color}
- id: touch_color
type: int [3]
restore_value: no
initial_value: ${touch_color}
binary_sensor:
on_press:
- if:
condition:
lambda: "return ${toggle_relay_1_on_touch};"
then:
- switch.toggle: relay_1
- delay: ${button_on_time}
state: OFF
on_press:
- if:
condition:
then:
state: OFF
on_press:
- if:
condition:
then:
state: OFF
on_press:
- if:
condition:
then:
state: OFF
on_press:
- if:
condition:
then:
state: OFF
switch:
- platform: gpio
pin: ${relay_1_pin}
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on:
then:
on_turn_off:
then:
- platform: gpio
pin: ${vibra_motor_pin}
name: "${friendly_name} Vibration"
restore_mode: ALWAYS_OFF
on_turn_on:
- delay: ${vibra_time}
- switch.turn_off: vibra
- platform: gpio
pin: ${pa_power_pin}
internal: true
restore_mode: ALWAYS_ON
- platform: gpio
name: "touch panel power"
pin:
number: ${touchpanel_power_pin}
inverted: true
internal: true
restore_mode: RESTORE_DEFAULT_ON
internal: true
optimistic: true
on_turn_on:
then:
on_turn_off:
then:
optimistic: true
on_turn_on:
then:
on_turn_off:
then:
- platform: restart
light:
- platform: neopixelbus
type: GRB
variant: WS2811
pin: ${led_pin}
num_leds: 28
default_transition_length: 0s
effects:
- addressable_rainbow:
speed: 30
width: 8
- pulse:
transition_length: 1.4s
update_interval: 1s
on_turn_off:
then:
- platform: partition
name: "LEDs Button left"
internal: true
segments:
- id: leds
to: 11
name: "LEDs Nightlight"
internal: true
segments:
- id: leds
to: 6
- id: leds
to: 8
- id: leds
to: 10
- id: leds
to: 19
- id: leds
to: 27
- id: leds_top
to: 6
internal: true
segments:
- id: leds
to: 26
effects:
- addressable_scan:
speed: 10
width: 20
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: ${audio_sdata_pin}
i2s_audio_id: audio_i2s
i2s_comm_fmt: lsb
mode: mono
i2s_audio:
i2s_lrclk_pin: ${audio_lrclk_pin}
i2s_bclk_pin: ${audio_bclk_pin}
uart:
tx_pin: ${uart_tx_pin}
rx_pin: ${uart_rx_pin}
baud_rate: 115200
data_bits: 8
stop_bits: 1
parity: NONE
debug:
direction: RX
dummy_receiver: false
after:
timeout: 2s
bytes: 2048
sequence:
- lambda: UARTDebug::log_hex(direction, bytes, ' ');
tx_ultimate_touch:
uart: my_uart
on_press:
- switch.turn_on: vibra
- script.execute:
pos: !lambda "return touch.x;"
- script.execute: led_on_touch
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_press", "Touch Position: %d / State: %d", touch.x, touch.state);
on_release:
#- script.execute:
# id: handle_release
# pos: !lambda "return touch.x;"
#- switch.turn_on: vibra
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_release", "Release Position: %d / State: %d", touch.x, touch.state);
on_swipe_left:
#- script.execute: led_on_swipe_left
#- binary_sensor.template.publish:
# id: swipe_left
# state: ON
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_swipe_left", "Swipe Left Position: %d / State: %d", touch.x, touch.state);
on_swipe_right:
#- script.execute: led_on_swipe_right
# id: swipe_right
# state: ON
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_swipe_right", "Swipe Right Position: %d / State: %d", touch.x, touch.state);
on_full_touch_release:
#- script.execute: led_on_full_touch
# id: multi_touch
# state: ON
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_full_touch_release", "Full Touch Release Position: %d / State: %d", touch.x, touch.state);
on_long_touch_release:
- script.execute: led_on_long_touch
state: ON
- lambda: >
ESP_LOGD("tx_ultimate_touch.on_long_touch_release", "Long Touch Release Position: %d / State: %d", touch.x, touch.state);
time:
- platform: homeassistant
- platform: sntp
on_time:
# Every 1 minutes
- seconds: 0
minutes: /30
then:
sun:
latitude: ${latitude}
longitude: ${longitude}
script:
- id: refresh_nightlight
mode: restart
then:
- if:
condition:
lambda: 'return "${nightlight}" == "on";'
then:
- switch.turn_on:
else:
- switch.turn_off:
- id: refresh_led_default
mode: restart
then:
- light.turn_off: leds_top
- if:
condition:
lambda: "return id(nightlight).state || id(nightlight_active).state;"
then:
- script.execute: led_on_nightlight
else:
- light.turn_off: leds_nightlight
- id: led_on_button_left
mode: restart
then:
- light.turn_on:
brightness: ${button_brightness}
red: !lambda "return id(button_color)[0]/100.0;"
green: !lambda "return id(button_color)[1]/100.0;"
blue: !lambda "return id(button_color)[2]/100.0;"
- id: led_off_button_left
mode: restart
then:
- if:
condition:
then:
- light.turn_on:
brightness: ${nightlight_brightness}
red: !lambda "return id(nightlight_color)[0]/100.0;"
green: !lambda "return id(nightlight_color)[1]/100.0;"
blue: !lambda "return id(nightlight_color)[2]/100.0;"
else:
- light.turn_off:
- id: led_on_nightlight
mode: restart
then:
- light.turn_on:
- id: led_on_release
mode: restart
then:
- light.turn_off:
- id: led_on_touch
mode: restart
then:
- light.turn_on:
brightness: ${touch_brightness}
red: !lambda "return id(touch_color)[0]/100.0;"
green: !lambda "return id(touch_color)[1]/100.0;"
blue: !lambda "return id(touch_color)[2]/100.0;"
effect: ${touch_effect}
- delay: 6s
- id: led_on_swipe_left
mode: restart
then:
- light.turn_on:
brightness: ${swipe_left_brightness}
red: !lambda "return id(swipe_left_color)[0]/100.0;"
green: !lambda "return id(swipe_left_color)[1]/100.0;"
blue: !lambda "return id(swipe_left_color)[2]/100.0;"
effect: ${swipe_left_effect}
- id: led_on_swipe_right
mode: restart
then:
- light.turn_on:
brightness: ${swipe_right_brightness}
red: !lambda "return id(swipe_right_color)[0]/100.0;"
green: !lambda "return id(swipe_right_color)[1]/100.0;"
blue: !lambda "return id(swipe_right_color)[2]/100.0;"
effect: ${swipe_right_effect}
- id: led_on_full_touch
mode: restart
then:
- light.turn_on:
brightness: ${multi_touch_brightness}
red: !lambda "return id(multi_touch_color)[0]/100.0;"
green: !lambda "return id(multi_touch_color)[1]/100.0;"
blue: !lambda "return id(multi_touch_color)[2]/100.0;"
effect: ${multi_touch_effect}
- id: led_on_long_touch
mode: restart
then:
- light.turn_on:
brightness: ${long_press_brightness}
red: !lambda "return id(long_press_color)[0]/100.0;"
green: !lambda "return id(long_press_color)[1]/100.0;"
blue: !lambda "return id(long_press_color)[2]/100.0;"
effect: ${long_press_effect}
- id: handle_release
mode: restart
parameters:
pos: int
then:
- if:
condition:
lambda: "return ${relay_count}==1;"
then:
state: ON
- id: touch_led_marker
mode: restart
parameters:
state: int
pos: int
then:
- if:
condition:
lambda: "return state==1;"
then:
# RELEASE
else:
- if:
condition:
lambda: "return state==2;"
then:
# TOUCH
- light.turn_on:
red: 1
green: 0
blue: 0
- delay: 6s
else:
- if:
condition:
lambda: "return state==11;"
then:
# FULL-TOUCH RELEASE
- light.turn_on:
effect: "Rainbow"
- delay: 1s
else:
# SWIPE
- if:
condition:
lambda: "return state==13;"
then:
# SWIPE LEFT
- light.turn_on:
red: 0
green: 1
blue: 0
- if:
condition:
lambda: "return state==12;"
then:
# SWIPE RIGHT
- light.turn_on:
red: 0
green: 0
blue: 1
- delay: 1s
