How do you take off the touch panel then once installed?
Also how did you grind it? dremel? if so what bit did you use?
To take it off i just use a screwdriver at the bottom of the switchplate and twist.(no easy but doable) and i used a 4" grinder, not optimal but it worked. A dremel with a cut of wheel would have been much better.
