I’m pulling my hair out trying to work out why my sonoff USB3.0 radio no longer initialises in HA after I updated the docker container to latest stable version. I’ve tried firmware update (which was successful) but am stuck with this error
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 665, in _skip_bootloader
result = await responses.get()
File "/usr/local/lib/python3.10/asyncio/queues.py", line 159, in get
await getter
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 122, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 200, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 171, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 145, in startup
await self.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 107, in connect
await znp.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 707, in connect
self.capabilities = (await self._skip_bootloader()).Capabilities
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 664, in _skip_bootloader
async with async_timeout.timeout(CONNECT_PROBE_TIMEOUT):
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
Any help in the right direction gratefully received. I had 16 devices in the zigbee network and would ideally like to avoid having to buy a new radio module and starting again from scratch :-/
