This is the Log of Zigbee2MQTT:
[16:52:13] INFO: Preparing to start...
[16:52:14] INFO: Socat not enabled
[16:52:16] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-02-06 16:52:21: Logging to console and directory: '/config/zigbee2mqtt/log/2023-02-06.16-52-21' filename: log.txt
Zigbee2MQTT:info 2023-02-06 16:52:21: Starting Zigbee2MQTT version 1.30.0 (commit #unknown)
Zigbee2MQTT:info 2023-02-06 16:52:22: Starting zigbee-herdsman (0.14.89)
Zigbee2MQTT:info 2023-02-06 16:52:26: zigbee-herdsman started (reset)
Zigbee2MQTT:info 2023-02-06 16:52:26: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:info 2023-02-06 16:52:26: Currently 0 devices are joined:
Zigbee2MQTT:warn 2023-02-06 16:52:26: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2023-02-06 16:52:26: Allowing new devices to join.
Zigbee2MQTT:warn 2023-02-06 16:52:26: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2023-02-06 16:52:26: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-02-06 16:52:27: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2023-02-06 16:52:27: Connected to MQTT server
Zigbee2MQTT:info 2023-02-06 16:52:27: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2023-02-06 16:52:27: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2023-02-06 16:52:27: Zigbee2MQTT started!
