I registered a few weeks ago this device using ZHA in HA at the first attempt and was working correctly for weeks. I could open and close the valve from the HA, see the water volume, etc. At that time I think I was at 2025.5.2 or 2025.5.3; OS 15.2
However, a few days ago when I sent the command to open the valve from HA and it didn’t respond. I restarted HA and nothing. I checked manually the physical device at it works when you press the physical button to open and close the valve.
So I tried to delete it and link it again on HA. However, each time I try to do so the device it’s detected but it gets stuck in the Configuring step, not finalising the process ever. The only change I did in that period of time was to update HA to 2025.6.1 so I’m not sure if it was related.
I’ll be travelling in the next weeks and I’m a bit worried that my plants and trees can die in this period because of the summer temperatures. : (
Anyone else with this issue? If so, did you find any solution? I opened an issue in the dev team github a few days ago but I did not receive answer yet:
