Sonoff ZB Bridge 1st gen integration issue
Hi everyone
I have a 1st gen Sonoff ZB Bridge which used to work, I was controlling my Weiser SmartCode 10 with it. I neglected HA for a few months and it stopped working. I started troubleshooting it by revisiting the original configuration and I am hitting a wall.
I can access the bridge via web and I can see all the Tasmota options seem to work (Tasmota 13.2.0).
The problem
When I go to integrations and select ZHA-EZSP
Failed to connect
If I select ZNP, I get the same error. I don’t get anything in the logs either.
I tried running an OTA upgrade, but nothing changed.
Has something changed or am I doing something wrong? it seems like the bridge is not responding to socket requests to port 8888.
This is the console log, I don’t see any entries for the port setup, it only shows the failed MQTT connection attempts:
22:00:07.798 MQT: Attempting connection...
22:00:07.812 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:02:08.783 MQT: Attempting connection...
22:02:08.794 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:04:09.754 MQT: Attempting connection...
22:04:09.769 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:05:06.301 RSL: STATE = {"Time":"2023-11-01T22:05:06","Uptime":"1T01:25:05","UptimeSec":91505,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":11,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":9,"Downtime":"0T00:00:25"}}
22:06:10.768 MQT: Attempting connection...
22:06:10.782 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:08:11.769 MQT: Attempting connection...
22:08:11.784 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:10:06.313 RSL: STATE = {"Time":"2023-11-01T22:10:06","Uptime":"1T01:30:05","UptimeSec":91805,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":11,"Mode":"11n","RSSI":100,"Signal":-48,"LinkCount":9,"Downtime":"0T00:00:25"}}
22:10:12.771 MQT: Attempting connection...
22:10:12.788 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:12:13.767 MQT: Attempting connection...
22:12:13.781 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:14:14.783 MQT: Attempting connection...
22:14:14.798 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:15:06.286 RSL: STATE = {"Time":"2023-11-01T22:15:06","Uptime":"1T01:35:05","UptimeSec":92105,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":11,"Mode":"11n","RSSI":98,"Signal":-51,"LinkCount":9,"Downtime":"0T00:00:25"}}
22:15:50.442 HTP: Main Menu
22:16:15.791 MQT: Attempting connection...
22:16:15.800 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:18:16.766 MQT: Attempting connection...
22:18:16.776 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:19:56.945 HTP: Configuration
22:20:01.528 WIF: Network (re)scan started...
22:20:06.291 RSL: STATE = {"Time":"2023-11-01T22:20:06","Uptime":"1T01:40:05","UptimeSec":92405,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":1,"Mode":"11n","RSSI":100,"Signal":-49,"LinkCount":9,"Downtime":"0T00:00:25"}}
22:20:18.760 MQT: Attempting connection...
22:20:18.786 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:20:49.506 HTP: Configure Module
22:21:00.487 HTP: Configuration
22:21:42.251 HTP: Main Menu
22:21:44.068 HTP: Firmware Upgrade
22:22:20.019 MQT: Attempting connection...
22:22:20.039 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:24:21.032 MQT: Attempting connection...
22:24:21.043 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:25:06.307 RSL: STATE = {"Time":"2023-11-01T22:25:06","Uptime":"1T01:45:05","UptimeSec":92705,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":11,"Mode":"11n","RSSI":100,"Signal":-47,"LinkCount":10,"Downtime":"0T00:00:26"}}
22:26:22.005 MQT: Attempting connection...
22:26:22.033 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:27:30.880 HTP: Main Menu
22:27:32.893 HTP: Configuration
22:27:34.204 HTP: Configure Module
22:28:23.009 MQT: Attempting connection...
22:28:23.024 MQT: Connect failed to 192.168.2.165:1883, rc -2. Retry in 120 sec
22:29:29.756 HTP: Configuration
22:29:35.153 HTP: Configure Module
22:29:37.182 HTP: Configuration
22:29:39.185 HTP: Main Menu
22:29:40.355 HTP: Console
22:30:06.311 RSL: STATE = {"Time":"2023-11-01T22:30:06","Uptime":"1T01:50:05","UptimeSec":93005,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":1,"SSId":"BELL886","BSSId":"3A:66:85:04:3F:C5","Channel":11,"Mode":"11n","RSSI":100,"Signal":-47,"LinkCount":10,"Downtime":"0T00:00:26"}}
