Sonoff zbdongle E as zigbee router
I installed this firmware:
But using the web tool, at the end of the firmware installation, I can no longer connect to the key.
Then how should I connect it to the Zigbee coordinator?
I use Z2M
Pair to Zigbee2MQTT:
you need to press boot button for about 5 seconds, until the green led start flashing.
I can’t see boot button: I have to remove cover on ITEAD SONOFF ZBDongle-E?
Yes, boot button is inside
