Good day to all.
Has anyone encountered the problem of the firmware crashing on the Sonoff ZBDongle-E?
In devices it is defined as USB–Enhanced-Serial ch9102. The driver does not install (it says that an up-to-date or new version of the driver has been installed). When I try to connect via Flash Programmer 2 (I specify the CC2652P device), the program crashes.
I don’t know what to do. I find information that ZBDongle-E is experimental, and maybe i just should to order SONOFF ZB Dongle-P?
The dongle E is not a CC2652 device, it contains a silabs chipset.
Flash here:
SONOFF Dongle-E, ZB-GW04, SMLIGHT SLZB07
I tried it to. After flash it was say like “flash is done”. But after all it doesn’t work.
And now, when i try to set cp2102 driver windows says “the best drivers for your device is already installed” and nothing changes.
How do you run HA ?
Virtual Machine in Virtual Box.
OS where i try install dongle - win10.
You don’t need to do anything with the dongle in Windows, just pass it through to the VM.
I did it, now Zigbee2MQTT says (:
[11:31:48] INFO: Preparing to start...
[11:31:50] INFO: Socat enabled
[11:31:51] INFO: Starting socat
Socat startup parameters:
Options: -d -d
Master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
Slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
[11:31:51] INFO: Starting socat process ...
2024/05/11 11:31:51 socat[47] N PTY is /dev/pts/0
2024/05/11 11:31:51 socat[47] N listening on AF=2 0.0.0.0:8485
[11:31:52] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-05-11 11:32:14: Logging to console and directory: '/config/zigbee2mqtt/log/2024-05-11.11-32-14' filename: log.txt
Zigbee2MQTT:info 2024-05-11 11:32:14: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-05-11 11:32:14: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-05-11 11:32:36: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-05-11 11:32:36: Failed to start zigbee
Zigbee2MQTT:error 2024-05-11 11:32:36: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-05-11 11:32:36: Exiting...
Zigbee2MQTT:error 2024-05-11 11:32:36: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:60:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Here’s my settings:
In device manager = COM3.
Zigbee2MQTT serial:
port: /dev/ttyS1
Your Zigbee2MQTT is still wrong. Maybe show your Zigbee2MQTT configuration.
Your mqtt setting is an issue. It’s been a minute since I was on a USB dongle, but the port settings ok. Test the mqtt settings and let us know.
server: mqtt://core-mosquitto:1883
Same error, i tried:
basetopic: zigbee2mqtt
user: mqtt
password: mqtt
Result:
[13:18:24] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-05-11 13:18:27: Logging to console and directory: '/config/zigbee2mqtt/log/2024-05-11.13-18-27' filename: log.txt
Zigbee2MQTT:info 2024-05-11 13:18:27: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-05-11 13:18:27: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-05-11 13:18:47: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-05-11 13:18:47: Failed to start zigbee
Zigbee2MQTT:error 2024-05-11 13:18:47: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-05-11 13:18:47: Exiting...
Zigbee2MQTT:error 2024-05-11 13:18:47: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at start (/app/index.js:107:5)```
And:
Result:
[13:22:09] INFO: Preparing to start...
[13:22:09] INFO: Socat enabled
[13:22:09] INFO: Starting socat
Options: -d -d
[13:22:09] INFO: Starting socat process ...
2024/05/11 13:22:09 socat[47] N PTY is /dev/pts/0
2024/05/11 13:22:09 socat[47] N listening on AF=2 0.0.0.0:8485
[13:22:10] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-05-11 13:22:13: Logging to console and directory: '/config/zigbee2mqtt/log/2024-05-11.13-22-13' filename: log.txt
Zigbee2MQTT:info 2024-05-11 13:22:13: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-05-11 13:22:13: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-05-11 13:22:34: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-05-11 13:22:34: Failed to start zigbee
Zigbee2MQTT:error 2024-05-11 13:22:34: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-05-11 13:22:34: Exiting...
Zigbee2MQTT:error 2024-05-11 13:22:34: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
Set socat to disabled
Add
adapter: ezsp
to serial
Is it disabled or false?
enabled: false
Now it works (after adding adapter: ezsp). You’re all beautiful, thank you!!!
Share your YAML config for others…like this
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
serial:
port: xxxxx
Like this?
mqtt:
user: addons
password: ***
serial:
port: /dev/ttyS2
adapter: zstack
mqtt:
user: addons
password: ***
frontend:
port: 8099
serial:
port: /dev/ttyS1
adapter: ezsp
device_options:
legacy: false
devices:
'0x54ef441000ae3d83':
friendly_name: '0x54ef441000ae3d83'
'0x00158d000833017c':
friendly_name: '0x00158d000833017c'
availability:
active:
timeout: 10
passive:
timeout: 1
