I just installed a new ZBMini Extreme into a bathroom pull switch and synced it into my Tuya ZB Gateway. The mini is seen as a Switch and operates correctly via Tuya Smart and Home Assistant but the actual physical pull switch is acting up. If I pull the switch once, it will not activate the mini and turn on/off the light however, if I pull the switch two times in quick succession it works.
I don’t want to have to train my family to “double click” the light switch so is there something I need to change to make it all work correctly?
Yes, and you were right, after reading the full manual online it does default to rocker mode so I just had to pull it out again, press the button 3 times to change the switch type (flashes 3 times in response), and now it’s working correctly.
