Based on A Raspberry Pi with a Conbee II .
Initially I set up several devices (Door switch, thermometer…) and these workd fine and still work
Then I added 3 Sonoff in wall ZBMINI switches.
They pair OK, they work correctly from the wall switch.
In Home Assistant they show up, but if you click one in HA to turn on or off, the light turns on or off, then the switch in HA returns to the original position and the Light icon does not turn Yellow (or blue).
IF you then click the switch icon in HA twice (when the light is on) to turn on then turn off, the light turns off.(sometimes)
If you turn on the light with the wall switch, sometimes you can turn it off with the HA
It is as if the ZBMINI is not sharing its state with HA if it is switched through Zigbee, but it will if it is switched manually from the connected wall switch.
Does anyone have any thoughts about what is happening ?
