A question for all ZBMini users,
I’ve been running a Zigbee network (using Zigbee2MQTT) with 20+ ZBmini devices (an growing) in my house for the best part of 3 years now. Overall has been a great solution, but I do have one issue which annoys me continually and I’m hoping someone has previously solved. I have 2 toilet light/fans each using a ZBMini and and two other exhaust fans each using a ZBMini. All my lights which are solely resistive loads (typically LED bulbs) work perfectly. However all the ZBminis with fans connected have switch bounce issues, particularly when switching with the physically switch (both on and off). It often takes multiple switches to get the fans to change state which is extremely annoying. I suspect this is because the fans are inductive loads (motors) and therefore play havoc with the ZBmini switch bounce. I know from previously playing with the Sonoff Basic there was a potential solution as discussed here: Sonoff flickering with GPIO14 and GND connected.
Would be keen to know if others have encountered this and have any solutions which successfully eliminated the switch bounce.
Btw, all ZBminis are the originals with neutrals connected (not -L) and working on Australian 240V power system.
Thanks.
