SONOFF ZBMINI Zigbee and Push Buttons
Hello
is it possible to controll a SONOFF ZBMINI (ZIGBEE, not WIFI) with a Push Button?
regard
Sorry, no. It doesn’t support momentary, only toggle switches.
Update: See below, there seems to one a way to enable this support by clicking the button 3 times.
ok, then i need a new zigbee switch.
the ZBMINI cannot be used for a two-way circuit if there are 5 wires between the switches.
3 I need for the lamps, 2 I have over for the switches. At
Sheely that was enough, because it could also pushbuttons.
Not true - Pulse mode
Must be a new mode or external config for the ZB-mini as there is no way to enable this via ZHA.
How did you get it to work?
pressed button on the mini, i think, 3 times? not sure, but it worked for me
this method worked on zbminil2 so i tried on clasic zbmini (bought yesterday) and it worked…
at least for me… :slight_smile:
