Hi, I am hoping for some help to allow me to install a SONOFF ZBMINIL2 into what I think is an intermediate switching setup. I am not a total moron but simple instructions of what to wire where would be great if you are able to help.
I believe I have this setup for a landing light with one switch downstairs and two upstairs.
From what I can gather it would be possible to wire this behind the switch with COM, L1 and L2, but I am stuck.
Would someone be able to talk me through this, ideally in terms of “your current black COM goes to L in and then L Out goes to the switch COM” etc.
Many thanks in advance, I have tried searching, but have not found anything for my setup.
If using a momentary switch would make it easier I am happy to buy one.
great video, didn’t know this was possible with the R4.
I have a few kicking about will have a play with one.
only downside is the size. would need a larger pendant cup to house the r4
Thanks for that. I got very excited thinking I could solve all this with one jumper cable and then towards the end of the video got very confused when he rushed through the UK setup. I am still lost.
I have it worked out. I have been totally thrown by the fact that the switched live and neutral wires from my light to the rose were the wrong way around. I was basing everything that was happening at the ceiling rose on the colours of the blue/brown from the light fitting. Once I actually tested them I found that whoever installed the light put them on incorrectly.
Now I know this then it is easy to follow this video and use a Sonoff Extreme MINIr4 in the ceiling rose. I will get one purchased.
Many thanks for all the advice and as a bonus I can now also buy a bunch of basic R4 units for other lights around the house and get those wired in correctly.
Just a last follow up, this all went well. I was just thrown by whomever installed the previous fitting as they had all the wiring messed up and not like convention. The hardest part was getting the Sonoff to actually pair, for some reason it took about 5 attempts.
