Set up my ZHA integration with various devices in 2 nearby buildings. To extend range I used ZBR3 which I can make working as repeater (signal extender). All attempts to add devices to ZBR3 directly have failed (with Add devices via this device selection). So a ZB noob question- have I to create a cluster or something on ZBR3 or…
Best, JR
You should be able to join via a ZBR3 without to many issues. I have four of them and they work ok as routers but I have had some issues with them going offline occasionally.
Thanks for a reply
I am using Tasmotized ZbBridge with HA ZHA integration. As my ZBR3-s work as repeaters (I guess) no dropouts in 2 months (noob to zigbee). Wondering if there is a device limit here before purchasing more Zigbee devices? Is it limited by ZbBridge or all managed by ZHA with zigbee.db database (as I understood Tasmotized ZbBridge acts as bridge from Zigbee to WiFi and HA ZHA integration)?
I can add devices at remote location but not via ZBR3 settings but with general ZHA device settings.
Best, JR
Made a small test network (good that I ordered 2 ZbBridges and Tasmotized them )
Here is the result but not sure how to interpret it:
No info on colors yet (it is ZigZag component) and no idea if Basics act as routers
Best, JR
Edit: colors are sorted out but they are false due to zha_map reporting to ZigZag via neighbour files…
Issue filed on GitHub
