Hi All,
The Sonoff Zigee 3.0 Dongle plus just arrived and flashed the following firmware on it:
/Koenkk/Z-Stack-firmware/blob/master/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20220219.zip
I had one CC2531 laying around and installed the router software on it:
/Koenkk/Z-Stack-firmware/blob/master/router/Z-Stack_Home_1.2/bin/CC2531_router_2020_09_29.zip
I installed Zigbee2MQTT and configured everything and tried to add my devices.
My sensors do connect with the Sonoff (Coordinator) and my CC2531 (router) connects with it.
Problem:
All my sensors won’t connect to the router and goes directly to the coordinator.
When I load my map in Zigbee2MQTT I get an error by loading LQI for the router, see image below.
Could someone help me how to connect the sensors to the router instead of the coordinator?
Log:
Error 2022-11-16 20:42:52Failed to execute LQI for 'CC2531_router_1'
Info 2022-11-16 20:42:52Network scan finished
Info 2022-11-16 20:42:52MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[{"depth":1,"linkquality":159,"lqi":159,"relationship":1,"routes":[],"source":{"ieeeAddr":"0x04cf8cdf3c773856","networkAddress":57453},"sourceIeeeAddr":"0x04cf8cdf3c773856","sourceNwkAddr":57453,"target":{"ieeeAddr":"0x00124b0026e31491","networkAddress":0},"targetIeeeAddr":"0x00124b0026e31491"},{"depth":1,"linkquality":129,"lqi":129,"relationship":1,"routes":[],"source":{"ieeeAddr":"0x00124b001cd4b6da","networkAddress":55513},"sourceIeeeAddr":"0x00124b001cd4b6da","sourceNwkAddr":55513,"target":{"ieeeAddr":"0x00124b0026e31491","networkAddress":0},"targetIeeeAddr":"0x00124b0026e31491"},{"depth":1,"linkquality":94,"lqi":94,"relationship":1,"routes":[],"source":{"ieeeAddr":"0x00158d000450a343","networkAddress":28174},"sourceIeeeAddr":"0x00158d000450a343","sourceNwkAddr":28174,"target":{"ieeeAddr":"0x00124b0026e31491","networkAddress":0},"targetIeeeAddr":"0x00124b0026e31491"},{"depth":1,"linkquality":254,"lqi":254,"relationship":1,"routes":[],"source":{"ieeeAddr":"0x00158d0002b57ac8","networkAddress":51479},"sourceIeeeAddr":"0x00158d0002b57ac8","sourceNwkAddr":51479,"target":{"ieeeAddr":"0x00124b0026e31491","networkAddress":0},"targetIeeeAddr":"0x00124b0026e31491"},{"depth":255,"linkquality":154,"lqi":154,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b0014d90d09","networkAddress":0},"sourceIeeeAddr":"0x00124b0014d90d09","sourceNwkAddr":0,"target":{"ieeeAddr":"0x00124b0026e31491","networkAddress":0},"targetIeeeAddr":"0x00124b0026e31491"}],"nodes":[{"definition":null,"failed":[],"friendlyName":"Coordinator","ieeeAddr":"0x00124b0026e31491","lastSeen":1668627686361,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"MiJia light intensity sensor","model":"GZCGQ01LM","supports":"battery, voltage, illuminance, illuminance_lux, power_outage_count, linkquality","vendor":"Xiaomi"},"friendlyName":"lichtsensor","ieeeAddr":"0x04cf8cdf3c773856","lastSeen":1668625874658,"manufacturerName":"LUMI","modelID":"lumi.sen_ill.mgl01","networkAddress":57453,"type":"EndDevice"},{"definition":{"description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","model":"CC2530.ROUTER","supports":"led, linkquality","vendor":"Custom devices (DiY)"},"failed":["lqi"],"friendlyName":"CC2531_router_1","ieeeAddr":"0x00124b001cd4b6da","lastSeen":1668627714440,"manufacturerName":"LUMI","modelID":"lumi.router","networkAddress":55513,"type":"Router"},{"definition":{"description":"Aqara wireless switch","model":"WXKG11LM","supports":"battery, voltage, action, device_temperature, power_outage_count, linkquality","vendor":"Xiaomi"},"friendlyName":"schakelaar_1","ieeeAddr":"0x00158d000450a343","lastSeen":1668627296224,"manufacturerName":"LUMI","modelID":"lumi.remote.b1acn01","networkAddress":28174,"type":"EndDevice"},{"definition":{"description":"Aqara temperature, humidity and pressure sensor","model":"WSDCGQ11LM","supports":"battery, temperature, humidity, pressure, voltage, linkquality","vendor":"Xiaomi"},"friendlyName":"temperatuur_1","ieeeAddr":"0x00158d0002b57ac8","lastSeen":1668627756066,"manufacturerName":"LUMI","modelID":"lumi.weather","networkAddress":51479,"type":"EndDevice"}]}},"status":"ok","transaction":"i93w1-9"}'
