I am a total novice and am trying to do some simple automation and am stuck configuring the dongle.
I have no programing abilities so I am stuck.
This is the failure error, get am warned that it is unformatted code but posted it anyway.
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:182
First occurred: 8:13:31 AM (1 occurrences)
Last logged: 8:13:31 AM
Error setting up entry Sonoff Zigbee 3.0 USB Dong - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c41c9fca5486ec11b011e53719c2d21c-if00-port0, s/n: c41c9fca5486ec11b011e53719c2d21c - ITead - 10C4:EA60 for zha
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 335, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 102, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 182, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.9/site-packages/zigpy/application.py”, line 69, in new
await app.startup(auto_form)
File “/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py”, line 152, in startup
return await self._startup(
File “/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py”, line 172, in _startup
await self._migrate_nvram()
File “/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py”, line 978, in _migrate_nvram
await self._znp.nvram.osal_write(
File “/usr/local/lib/python3.9/site-packages/zigpy_znp/nvram.py”, line 128, in osal_write
await self.znp.request(
File “/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py”, line 856, in request
raise InvalidCommandResponse(
zigpy_znp.exceptions.InvalidCommandResponse: Expected SRSP response SYS.OSALNVItemInit.Rsp(Status=<Status.NV_ITEM_UNINIT: 9>), got SYS.OSALNVItemInit.Rsp(Status=<Status.NV_OPER_FAILED: 10>)
